Last Post: Rolschnee
0 1970 XLH Tach cable kinked
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 S&S Super B help
Last Post: Gravitas
0 Swing arm bearing change
Last Post: SportsterXLCH1967
0 2018 Iron 1275 Project
Last Post: yelladox
0 Homemade Lithium Battery
Last Post: t120r
Last Post: Firefight
0 1968 ex barn dweller thread
Last Post: fernf5
Last Post: mikethebike61
0 WTB 04-06 intake manifold
0 Swingarm Fitment
Last Post: Blacky
0 yost power tube guy
Last Post: cazz1000
0 S&S Super E
Last Post: CMCSSeabee
Last Post: Magneto Sportster
0 I made a oopsie
Last Post: robbie202
0 RIP Trainman
Old 2 Weeks Ago
VintageVinny VintageVinny is offline
Sportster/Buell Model: 1974 Sportster
VintageVinny is an unknown quantity at this point
Default 74 Sportster Starter Issue - No Crank
I'm starting with a new fully charged battery.
Voltage to the solenoid (tall lug) is 12.6 volts.
When the starter button is activated, without the starter connected,
voltage out of the solenoid (short lug) is 11.5 volts.
But- when I connect the solenoid (short lug) to the starter, the voltage out of the solenoid drops to 0.9 volts when the starter button is activated.
My first thought is there's an open short in the starter.
But what's puzzling is, I can put direct power to the starter and it spins.
Any thoughts?
Old 2 Weeks Ago
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Not really an introduction thread, so moving to the Ironhead section.
Folkie
South East England Riders
Old 2 Weeks Ago
doodah man's Avatar
Change the wire between the solenoid and starter and see if it’s back to normal.
Old 2 Weeks Ago
What is the voltage across the battery when cranking?
Old 2 Weeks Ago
The Doctor71 The Doctor71 is online now
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
Didn't we just deal with this on your bike ?
http://xlforum.net/forums/showthread.php?t=2078891
New thread but same issue ? Or am I mis-understanding the history of this problem ?
Old 2 Weeks Ago
Answer to "Didn't we just deal with this on your bike ?"
Yes. Thought it was the battery so I replaced it. But having the same problem.
Answer to "What is the voltage across the battery when cranking?"
Right now, the battery's a little low from testing and is at 12.3 volts.
When cranking starter dips to 11.9 volts.
Answer to "Change the wire between the solenoid and starter."
I don't have another cable to try, but resistance on cable with multimeter is .16 ohms.
Old 2 Weeks Ago
BigMek's Avatar
BigMek BigMek is offline
Sportster/Buell Year: 1982
BigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond repute
0.16 ohms is actually pretty high considering how thick and short that wire is. Nominal resistance of an 8-gauge stranded copper wire is roughly 0.70 ohms per thousand feet. This means your starter wire should have a resistance around 0.0014 ohms (assuming it's roughly two feet long), so your wire's resistance is 100 times higher than it should be. That's probably conservative too, since I think the stock wire is 6 gauge which is 0.45 ohms per thousand feet.
By Ohm's law, that much resistance will also limit your max current to only 76 amps, less than half the CCA of your battery. The starter might simply not be getting enough current to turn.
Old 2 Weeks Ago
Thank you BigMek, that just might be the problem.
Could you please verify that I am reading the multimeter right?
Resistance shows 1.6 on 200k ohms, 0.16 on 20m, and .2 on 20k ohms.
Old 2 Weeks Ago
BigMek's Avatar
Can you double-check your readings and meter settings? They're not lining up.
The K and M stand for Kilo and Mega, so whatever the display says you have to multiply by 1,000 for K, or 1 million for M, to get the actual value. Example, 1.0 on the 20k scale is 1 kilo-ohm (pronounced kil-ohm) or 1,000 ohms. Different values in each scale (2k vs. 20k vs. 200k) choose the highest value your meter can show, but shouldn't change the reading unless the meter starts rounding.
Here are some samples from my meter with three 510 ohm resistors in series.
1.510 on 2k, 1.51 on 20k, 01.5 on 200k, 0.001 on 2M, and zero on 20M because it's off the scale.
Old 2 Weeks Ago
Thank you BigMek. Each time I test the cable, I get different readings, so maybe the battery needs to be replaced. My last readings were:
2.65 on 20k, 20.5 on 200k, and 2.05 on 20M
