xl1200T
Last Post: luce26
2 Weeks Ago
Posts: 11,069 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
If you are able to crank it over strong with direct power from the battery, then there has to be a faulty connection or wire in the system.
2 Weeks Ago
Posts: 32 Sportster/Buell Model: 1974 Sportster Sportster/Buell Year: 1974
Thank you doodah man, that makes sense. The solenoid to starter cable may be where I'm losing voltage, so I have ordered a replacement.
2 Weeks Ago
Usually a bad battery cable will make itself known by getting hot.
2 Weeks Ago
With a fresh battery in the multimeter:
Starter cable resistance shows 3.5 on 200k, .33 on 20m, and .48 on 20k ohms
Pos cable resistance shows 3.4 on 200k, .31 on 20m, and .45 on 20k ohms
Neg cable resistance shows 2.5 on 200k, .25 on 20m, and .38 on 20k ohms
Do these sound normal ?
2 Weeks Ago
Resistance checks on battery cables is not a effective test.
Better to do a voltage drop test when cranking across the cable.
2 Weeks Ago
Thank you Ryder Rick for that clarification.
That validates my previous post, that when the starter is activated,
the voltage at the end of the starter cable drops from 11 volts to .9 volts
2 Weeks Ago
Posts: 485 Sportster/Buell Model: 1200C Sportster/Buell Year: 2006 Other Motorcycle Model: Ducati Other Motorcycle Year: 1974
Also, check worth making is to touch your meter leads together and see what the ohm reading on the lowest scale is. Should be 0.00 to 0.01. What do you get with your meter?
2006 1200c: Home Made a/c, Cycle Shack Slipons, Daytona TC88A w/JesterVII map (thank you, Rico), Street Trackers
2 Weeks Ago
"ohm reading on the lowest scale - Should be 0.00 to 0.01."
Putting the 2 leads together, it's reading 1.3 on 200k, .15 on 20m, and .19 on 20k ohms.
Should I deduct these figures from the other readings, or get a new multimeter ?!
2 Weeks Ago
Taking readings from the starter solenoid short fat lug -
Without the starter cable attached, solenoid output is 11.5 volts when starter button is activated.
With the starter cable attached, solenoid output is 0.9 volts when starter button is activated.
Can someone explain what would cause this ?
2 Weeks Ago
Posts: 246 Sportster/Buell Model: sportster xlch Sportster/Buell Year: 1970 Sportster/Buell Model #2: sportster xlh Sportster/Buell Year #2: 73 Other Motorcycle Model: 99 inch sportster Other Motorcycle Year: 2003
ironhead 74
The solenoid to starter wire is suspect for corrosion, frayed insulation,loose connections,grounding condition or all of the above.Replace it.
