0 What Is the Advantage - Shovster?
0 WTB 04-06 intake manifold
Last Post: SportsterXLCH1967
Last Post: Rolschnee
0 1970 XLH Tach cable kinked
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 S&S Super B help
Last Post: Gravitas
0 Swing arm bearing change
0 2018 Iron 1275 Project
Last Post: yelladox
0 Homemade Lithium Battery
Last Post: t120r
Last Post: Firefight
0 1968 ex barn dweller thread
Last Post: fernf5
0 Swingarm Fitment
Last Post: Blacky
0 yost power tube guy
Last Post: cazz1000
0 S&S Super E
Last Post: CMCSSeabee
Last Post: Magneto Sportster
0 I made a oopsie
Last Post: robbie202
Old 2 Weeks Ago
oldboy's Avatar
oldboy oldboy is offline
Other Motorcycle Model: Ducati
Other Motorcycle Year: 1974
oldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond reputeoldboy has a reputation beyond repute
"Should I deduct these figures from the other readings, or get a new multimeter ?"
deducting from your meter reading is fine.
2006 1200c: Home Made a/c, Cycle Shack Slipons, Daytona TC88A w/JesterVII map (thank you, Rico), Street Trackers
Old 2 Weeks Ago
VintageVinny VintageVinny is offline
Sportster/Buell Model: 1974 Sportster
VintageVinny is an unknown quantity at this point
Thank you oldboy, I will take up your suggestion.
Thank you sungod - That cable was my prime suspect.
I've ordered a new cable.
Old 2 Weeks Ago
To determine where the problem is:
I'm going to disconnect the green wire from the thin post on the solenoid, then momentarily attach a jumper wire directly from the positive battery terminal to the thin post on the solenoid.
If the starter spins, it tells me the ignition switch and/or wires are faulty.
If the starter doesn't spin, the solenoid and/or cable is faulty.
Does this sound logical?
Old 2 Weeks Ago
sungod's Avatar
sungod sungod is offline
Sportster/Buell Model: sportster xlch
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 73
sungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to all
Default 1974 starter
Vinny if you jump red to green at the starter relay with all the wires correctly connected and the solenoid correctly installed, you should crank the engine. Red wire is battery + and green is supply to small thin terminal on solenoid. Yes there will be an arc.
Old 2 Weeks Ago
"Jump red to green at the starter relay with all the wires correctly connected and the solenoid correctly installed, you should crank the engine."
Jumping red to green wires at the relay did not crank the engine.
My other test was, disconnect the green wire from the thin post on the solenoid, then momentarily attach a jumper wire directly from the positive battery terminal to the thin post on the solenoid.
This also failed to crank the motor.
Again, there is 12.5 volts going into the solenoid (tall fat stud), but with the starter hooked up, only 0.9 volts comes out of the solenoid when activated (short fat stud).
Is it possible my brand new solenoid is at fault ?
Old 2 Weeks Ago
Steve9's Avatar
Steve9 Steve9 is online now
Sportster/Buell Model #2: XL
Sportster/Buell Year #2: 1981
Other Motorcycle Model: FXDC
Electrical stuff-brand new does not always mean good.
Steve
'03 1250 NRHS stage two Lightning heads, 536, mik 42
'01 Cyclone
'13 FXDC 96" stock
Old 2 Weeks Ago
Yellowstone Kelly's Avatar
Ironhead Rider
Sportster/Buell Year: 1982
Sportster/Buell Year #2: 1969
Other Motorcycle Model: FLSTC
Other Motorcycle Year: 1996
Yellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond reputeYellowstone Kelly has a reputation beyond repute
Yes, it's possible the new solenoid is bad, based on what you've described as happening with your tests.
It's also possible there's a mechanical bind with the plunger or the "shifter lever" or other parts (see the diagram) that's keeping the plunger from pulling all the way in and electrically connecting the long stud to the short stud inside the solenoid.
When you activated the solenoid, did it make a loud "clunk" noise as the plunger pulled in?
"Never underestimate the power of human stupidity." Robert A. Heinlein
Old 2 Weeks Ago
sungod's Avatar
Default ironhead 74
Vinny I recall that you had replaced the solenoid several times with similar results. Are you positive the solenoid is properly installed? You ordered a new solenoid to starter wire but maybe remove the existing wire and fully inspect it.
Old 2 Weeks Ago
Good News - I swapped solenoids and now the starter is cranking great !
The faulty one was a "Standard" brand from J&P Cycle.
The one that's on there now and working is an Accel.
Thank you all for your time and patience !
Old 2 Weeks Ago
Solenoids are rebuildable, but it takes a fine hand.
You can buy a kit that has a new copper washer and both big terminals with a new bakelite cover and screws.
