2 Weeks Ago
Posts: 905 Sportster/Buell Model: 1968
Pingel - which?
Howdy folks...
Bendix carb, replacing this
Pingel petcocks seem tricky to acquire in UK so don’t want to get the wrong one...
This one?
Power-Flo Fuel Valve - 3/8in. NPT Hex - 180 Deg. Outlet Facing Inward - S
Part Number: 6291-CH
Tempting to go for the 90deg option and do away with the in line filter....
I’m guessing no reserve on this type of petcock?
Thanks
2 Weeks Ago
Posts: 438 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2006 Sportster/Buell Model #2: XLH1000 Sportster/Buell Year #2: 1979 Other Motorcycle Model: Wide Glide Other Motorcycle Year: 2013
I’ve got the 49-8852 / 6391-AH downward outlet 22mm version on my ‘79. It does have reserve on it. I’m not 100% sure if my gas tank is an OEM tank though so I’m not certain if 22mm is standard or not. I like the Golan petcocks more due to their detent feature but this is still a nice piece.
'06 Sportster / '79 Sportster / '13 Wide Glide
2 Weeks Ago
Originally Posted by wrkdWS6
I’ve got the 49-8852 / 6391-AH downward outlet 22mm version on my ‘79. It does have reserve on it. I’m not 100% sure if my gas tank is original though so I’m not certain if 22mm is standard or not. I like the Golan petcocks more due to their detent feature but this is still a nice piece.
Thanks.
Actually the Golan is more easily available, is it as good as a Pingel?
2 Weeks Ago
My tank definitely takes 3/8NPT
2 Weeks Ago
Posts: 14,509 Sportster/Buell Model: xlch Sportster/Buell Year: 1960
it has reserve.in your picture 3 positions off reserve on.i have a Pingel it has the same order.
2 Weeks Ago
Thanks.
Both the Pingle and the Golan are excellent units. They are equal in quality. Like I mentioned, the Golan has a nice detent feature so you know exactly when you’ve moved from one position to the next unlike with the Pingel. Looks are subjective but I like the look of the Pingel slightly more. The detent feature is why I like the Golan more overall but you can’t go wrong with either. I have run and currently run both brands on my bikes.
Here’s a video illustrating the detent feature:
https://m.youtube.com/watch?v=nyVce_sl-gU
2 Weeks Ago
Posts: 880 Sportster/Buell Model: xlch Sportster/Buell Year: 1971 Sportster/Buell Model #2: xlh Sportster/Buell Year #2: 1974 Other Motorcycle Model: xl1200cp Other Motorcycle Year: 2011
I have a Golan on my '74 XLH. It works. No complaints.
When sitting on the seat, the "lever" operates as: - OFF is at 6 o'clock
- ON is at 9 o'clock
- RESERVE is at 3 o'clock
and I seem to hit reserve sooner than the OEM petcock. (aka there's more reserve fuel with the Golan than the OEM setup)
2 Weeks Ago
Posts: 3,314 Sportster/Buell Model: XLCH Sportster/Buell Year: 1969 Sportster/Buell Model #2: XLH Sportster/Buell Year #2: 1960 Other Motorcycle Model: XLCH Other Motorcycle Year: 1959
Does the lever hit the rocker box when you try to go on reserve?
"Ride 'em, don't hide 'em!"
2 Weeks Ago
Magneto..... on my '74, the lever is at 3 o'clock for RESERVE, (aka lever is pointed at the air cleaner) so there's no clearance issues.
Things are slightly tighter for the ON position, as the lever is rotated under the tank, close to the throttle cable on my Bendix carb. But the clearance is still there.
Of course, this all applies to how I orientated the Golan in my '74 XLH tank. For the benefit of others..... one has to go thru a few fitment sessions so the alignment of the lever and the gas outlet port ends up where you want them, on your ride...... and still have the petcock tight enough to not leak at the threads. I purposely choose to have the lever at the back & the outlet port at the front. The installer has the option to orientate the lever / outlet port wherever they want..... as long as it doesn't leak  .
The other "odd" thing to get used to, with a Golan, is..... when you run out of gas, one has to rotate the lever from ON to OFF to RESERVE. Not a big deal, but it is different from an OEM petcock.
Here's a couple more pics I took this morning. The lever in all my pics is in the OFF position.
2 Weeks Ago
OK, thanks. I am considering upgrading the petcock on an XLH with the large capacity fuel tank, but the petcock is next to the rocker box on that tank, so it may be too tight.
