0 What Is the Advantage - Shovster?
0 WTB 04-06 intake manifold
Last Post: SportsterXLCH1967
Last Post: Rolschnee
0 1970 XLH Tach cable kinked
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 S&S Super B help
Last Post: Gravitas
0 Swing arm bearing change
0 2018 Iron 1275 Project
Last Post: yelladox
0 Homemade Lithium Battery
Last Post: t120r
Last Post: Firefight
0 1968 ex barn dweller thread
Last Post: fernf5
0 Swingarm Fitment
Last Post: Blacky
0 yost power tube guy
Last Post: cazz1000
0 S&S Super E
Last Post: CMCSSeabee
Last Post: Magneto Sportster
0 I made a oopsie
Last Post: robbie202
Old 2 Weeks Ago
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
ok, I think I figured out the reason for a bit of confusion (on my part anyway).....
Outlined in RED in the pic below, the entire bottom portion of the Golan rotates (not just the lever alone).
Old 2 Weeks Ago
nice to finally see a picture of the golan,i've been hearing about them for years.i think i like my pingel better but the detent feature with the golan is nice.
Old 2 Weeks Ago
davixlrtt's Avatar
davixlrtt davixlrtt is offline
Sportster/Buell Model: 1965 xlch
Sportster/Buell Model #2: 1991 Honda XR600
Other Motorcycle Model: 1986 suzuki gsxr 750.
davixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant futuredavixlrtt has a brilliant future
After I fitted my new Pingel the lever would move about on it’s own while riding and turn the fuel off randomly, after about a week I decided I would take it off but it suddenly started to play ball.
........Davi.
Old 2 Weeks Ago
..... but the detent feature with the golan is nice.
for sure..... the detents are quite positive on the Golan.
Old 2 Weeks Ago
mikethebike61's Avatar
Fuel inlet to rear? Install inlet fitting pointing straight up and use a left exit Pingle...this will allow you to run a 5" fuel line to carb that does not loop around bottom of carb.....just like a stock 1977 with stock Keihin
DirtyHarry68's Avatar
DirtyHarry68 DirtyHarry68 is offline
Sportster/Buell Model: 1968
DirtyHarry68 has disabled reputation
Found this Dapco tap in the parts stash, seems nice so going to give this a try before shelling out....can practically hear eyeballs rolling from here...got to be better than the trickle Im getting now.
It’s 1/4NPT so bought an adaptor...might lose some reserve.
