0 1970 XLH Tach cable kinked
Last Post: Rolschnee
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 S&S Super B help
Last Post: Gravitas
0 Swing arm bearing change
Last Post: SportsterXLCH1967
0 2018 Iron 1275 Project
Last Post: yelladox
0 Homemade Lithium Battery
Last Post: t120r
Last Post: Firefight
0 1968 ex barn dweller thread
Last Post: fernf5
Last Post: mikethebike61
0 WTB 04-06 intake manifold
0 Swingarm Fitment
Last Post: Blacky
0 yost power tube guy
Last Post: cazz1000
0 S&S Super E
Last Post: CMCSSeabee
Last Post: Magneto Sportster
0 I made a oopsie
Last Post: robbie202
0 RIP Trainman
Old 2 Weeks Ago
spiritof67 spiritof67 is offline
Sportster/Buell Model: XLCR
spiritof67 is a splendid one to beholdspiritof67 is a splendid one to beholdspiritof67 is a splendid one to beholdspiritof67 is a splendid one to beholdspiritof67 is a splendid one to beholdspiritof67 is a splendid one to beholdspiritof67 is a splendid one to beholdspiritof67 is a splendid one to beholdspiritof67 is a splendid one to beholdspiritof67 is a splendid one to beholdspiritof67 is a splendid one to behold
Default XLCR Rotors
I am looking into upgrading the front brake setup on my rider XLCR. The PM 4-piston caliper/cast iron disc setup I'm using is better than stock but marginal in the real world. It needs larger diameter discs. Has anyone run larger rotors on the '77 style wheel who can advise me? No lifestyle advice ("Ride it slower") please.
Old 2 Weeks Ago
84rzv500r 84rzv500r is offline
Sportster/Buell Model: XLH 1200 S
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 83
Other Motorcycle Model: RZV500R/R1 hybrid
Other Motorcycle Year: 1984
84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future
iron? IIRC XLCR rotors are stainless steel... ductile iron would be a good upgrade even at the same diameter 10"??... what is the weight bias on your front end? have you dropped the forks in the triple trees? more aggressive compound on the pads? stickier front tire? braided stainless lines? new brake fluid?
1999 1200 Sport, SE 7500 ignition, SE air filter, DynoJet , Cone Engineering 2:1 pipe, Storz Steering damper, Russel Mach 3 Stainless Lines, VROD 4 piston front calipers, Bates Baja tires, XR1200 perf shocks, forks and triples coming very soon...
1983 XR-1000S to XR-1000RX Project Build Thread
Old 2 Weeks Ago
Harley oversizes the front master cylinder in an attempt to keep inexperienced riders from locking the front wheel.
I would not run a stainless rotor they are for show bikes, brakes are not a place for compromises.
Stainless rotors are particular about what pads you use, so maybe check on different compounds before breaking the piggy bank open.
Old 2 Weeks Ago
Default XLCR Rotors
84RZV5000R, the PM rotors are ductile iron; I already have installed HH pads; I already have braided lines; and I have changed brake fluid numerous times. The simple fact is that the available swept area of 10" discs simply isn't sufficient to make it truly safe to ride in 21st Century conditions. That's why I'm trying to find larger diameter discs (hopefully EBC or similar swap-out) so I can mount larger and better calipers. Sadly, HD decided to unify the master cylinder and handlebar controls (stylish!) so I am stuck with the stock master.
By the way, how's that Yamaha? Steel frame or aluminum?
Old 2 Weeks Ago
hand welded aluminum.... RZV...
Old 2 Weeks Ago
Default XLCR Rotors
That's a great motorcycle. Suzuki decided for some reason not to go all the way with the Gamma, but Yamaha took the bit in their teeth (for one year?) and did the aluminum frame version. If I thought I could find someone to take proper care of it, I'd love to have one. Instead I have my XLCR and XR1000....
Old 2 Weeks Ago
Gammas make more power than rz(v)'s but if you strap on 3MA TZ250 cylinders to either look out... My RZV is a hybrid with 2002 R1 forks with Ohlins internals Ohlins Shock Marchesini M5's... I was thinking about selling it... it would be a lump magnesium oxide and titanium nuggets down here in the keys inside a year... 110 At the rear wheel and 319lbs Wet... and this always gets people who think two strokes are peaky... think R1 torque
https://photos.google.com/share/AF1Q...RXX05Vekl6Q3ZB
Old 2 Weeks Ago
Sportster/Buell Year: 1969
If you are happy with the feel of your current PM caliper/master cylinder combo and just want to increase disc size that should be simple. Find the size disc you want that will bolt to your hub, modify caliper bracket for caliper to align properly on new disc. The added disc area will improve thermal response and stopping.
Old 2 Weeks Ago
mikethebike61's Avatar
Wilwood disagrees
Brembo also disagrees
You can argue with them
Both my bikes run SS rotors
XLCH....WILWOOD
BMW.....BREMBO (STOCK OEM)
I'll put either of them up against anything in the same weight class...
Old 2 Weeks Ago
Go to WILWOOD site and look at their pads..they list a heat/coefficient of friction graph for each compound pad....I use PolyMatrix "E" pads on everything
C/F about 42-47 up to 900 degrees or so...
Used that compound on the GMC motor home and it transformed the beast..
