0 What Is the Advantage - Shovster?
0 WTB 04-06 intake manifold
Last Post: SportsterXLCH1967
Last Post: Rolschnee
0 1970 XLH Tach cable kinked
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 S&S Super B help
Last Post: Gravitas
0 Swing arm bearing change
0 2018 Iron 1275 Project
Last Post: yelladox
0 Homemade Lithium Battery
Last Post: t120r
Last Post: Firefight
0 1968 ex barn dweller thread
Last Post: fernf5
0 Swingarm Fitment
Last Post: Blacky
0 yost power tube guy
Last Post: cazz1000
0 S&S Super E
Last Post: CMCSSeabee
Last Post: Magneto Sportster
0 I made a oopsie
Last Post: robbie202
DR DICK's Avatar
DR DICK DR DICK is offline
Originally Posted by spiritof67 View Post
I am looking into upgrading the front brake setup on my rider XLCR. The PM 4-piston caliper/cast iron disc setup I'm using is better than stock but marginal in the real world. It needs larger diameter discs. Has anyone run larger rotors on the '77 style wheel who can advise me? No lifestyle advice ("Ride it slower") please.
i agree the 10"ers suck.
check out harley pn 44136-84. 11.5 inches
used on 84- 85 xl, 83 xr1000.
use the same bolt pattern as your 77 hub.
they uses different bolts head.
also has a larger bore to register to hub.
(ive installed rings to make up the difference, and also just bolted them up with no ring. no issues either way).
think they maybe a little thicker?? (+.020" cant remember for sure).
thats of no consequence to you as you will need different caliper hangers.
change caliper hanger thickness if ness.
when i used this set up with 4piston pm's (125x4) i used the pm -84 replacement iron rotors i learned this:
when calipers were mounted behind lower legs the brake power was exceptional, stoppies were no problem on a 480lb tin cover bike, but pad life was short. was due to calipers having no 'trail'.
the hanger wasnt beefy enuff to keep the caliper from swaying side to side under braking. when swayed the caliper/disc misalignment wrenched the pads tight against the disc. hence short pad life and the high stopping power.
when i flipped the calipers to front side of lower legs stopping power was reduced but pad life and lever feed back increased.
D.D._____________________________-o&o____________________________
84rzv500r 84rzv500r is offline
Sportster/Buell Model: XLH 1200 S
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 83
Other Motorcycle Model: RZV500R/R1 hybrid
Other Motorcycle Year: 1984
84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future84rzv500r has a brilliant future
I can measure the 83 XR 1000 rotors tomorrow if needed... i have a 12000 mile original set.... the 1999 XL1200S semi floating OEM rotors work just fine as well. MOCO offers these as replacment/upgrades still... the newer PN requires the hub centeric ring as an additional PN... the plus is that these are SunStar and you can drill out the 11 buttons and replace them with titanium buttons to fully float the rotors... Jingle Jingle
1999 1200 Sport, SE 7500 ignition, SE air filter, DynoJet , Cone Engineering 2:1 pipe, Storz Steering damper, Russel Mach 3 Stainless Lines, VROD 4 piston front calipers, Bates Baja tires, XR1200 perf shocks, forks and triples coming very soon...
1983 XR-1000S to XR-1000RX Project Build Thread
mikethebike61's Avatar
three ways to increase brake effectiveness....
2 are expensive and can get complex
1 is very affordable and EASY
1....increase leverage (bigger rotors)
2....increase pressure (redesign system)
3....increase coefficient of friction....(buy a more aggressive pad)
pretty easy decision for me
dont forget tire compound and profile where your braking forces are transferred to the ground
My post was in reference to your brake system and not tires....the thread is about improving the system....if your pads, rotors, etc are not up to the job your tires won't matter...
