0 WTB 04-06 intake manifold
Last Post: SportsterXLCH1967
Last Post: Rolschnee
0 1970 XLH Tach cable kinked
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 S&S Super B help
Last Post: Gravitas
0 Swing arm bearing change
0 2018 Iron 1275 Project
Last Post: yelladox
0 Homemade Lithium Battery
Last Post: t120r
Last Post: Firefight
0 1968 ex barn dweller thread
Last Post: fernf5
0 Swingarm Fitment
Last Post: Blacky
0 yost power tube guy
Last Post: cazz1000
0 S&S Super E
Last Post: CMCSSeabee
Last Post: Magneto Sportster
0 I made a oopsie
Last Post: robbie202
0 RIP Trainman
compression test
Old 2 Weeks Ago
Gravitas Gravitas is offline
Sportster/Buell Year: 1984
Gravitas is an unknown quantity at this point
Default Non-Starter, Compression Test Results
Hi,
Many thanks to all those who welcomed me to the forum.
I changed the plugs and the gas. Still does not start.
The old plugs had no oil on them.
The new plugs smell of gas after trying to start.
As recommended here, I have run a compression test.
Front Rear
Initial 80 psi Initial 0
With oil 105 With Oil 25
So even though, I thought the rear cylinder was "making an effort" with starter spray and the front was doing nothing. I guess I was wrong.
So, the front has low compression and the back looks awful.
I assume that I will need to dismantle the rear cylinder head and check for bent valves or a holed piston.
I have not tried adjusting the push-rods yet, I guess that could improve the front compression, but is not responsible for the rear - is that correct?
Any suggestions for the list of things to do now would be welcome!
Regards
Paul
Old 2 Weeks Ago
For the compression test it is important that the throttle be open while cranking, and that the engine be at full operating temperature. The front cylinder at 80 psi actually looks ok. Would make the 120 mark if fully warmed up. Perhaps not great but runnable.
You might test the rear cylinder again, unless you are experienced and confident in your technique.
Adjusting the pushrods [engine must be stone cold, I guess not a problem, eh ] may very well make a big, big difference. The valves may not be closing at all.
Old 2 Weeks Ago
doodah man's Avatar
If it were my bike, I would adjust the push rods first, then double check ignition timing is correct. Maybe even remove the plugs and reconnect the plug boots, ground the plugs on the engine and watch for them to spark just to prove they are working. Does your bike still have the original ignition?
Old 2 Weeks Ago
Many thanks to Mick and Doodah_Man.
I'll adjust the push rods. First I need a rear stand... And Imperial spanners and sockets.
As well as a full gasket set, and additional push rod O-rings.
I assume that I will need a friend to help get the beast onto the rear stand, since it would really annoy me if I dropped it...
Old 2 Weeks Ago
kitabel kitabel is online now
Sportster/Buell Year: 1989
There are only 2 pushrod settings that matter for starting:
1. valves close
2. valves do not close
Valves close + low reading: top end comes apart
Valves do not close: re-adjust pushrods
Old 2 Weeks Ago
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Only a few standard tools are needed to adj the pushrods.
1/2” open wrench
7/16” open wrench
Straight blade screwdriver to remove cover clips
Spark plug removal tools.
Pull plugs and while in 4th gear, roll the bike to position particular valve to lowest point. Adjust tappet. Repeat for remaining 3.
Reinstall clips, place in neutral, repeat comp test.
10 min job.
With a fresh valve job, it is not uncommon for valves to get tight in initial short run time.
Old 2 Weeks Ago
Ironhead Push Rod Adjustment
http://xlforum.net/forums/showthread.php?t=44143
If you have the actual Sportster centre stand then yes, you will appreciate an assistant. There are some tricks - like rolling the bike forward, rear wheel onto a piece of 2x6, then lower the stand and kick out the wood.
Old 2 Weeks Ago
11B40 11B40 is offline
The engine must be stone cold when adjusting the valves. You should adjust them until there is free turning and a bit of up and down movement. Check the results carefully. If the pushrods are tight you will burn a valve face within a few minutes of start up. If you adjust the valves while the engine is even warm, the iron parts will shrink as they cool and the valves will be slightly open for the next time you try to start it. In those few minutes that the engine takes to heat up and expand, the valve face will be burned as combustion gases escape past the valve. If you are lucky, you might be able to hand lap the valve and save it.
As Mick says, a compression test done incorrectly is a waste of time. The engine is designed to be at operating temperature to work well. If you get a marginal Compression test don't get hysterical about it and start ripping things apart. A lot of engines have so-so compression tests and still operate fine. Have a good reason before you tear off the heads and barrels. Excessive oil consumption, blow by causing excess oil loss through
leaks and breather loss.
The work to pull the heads and barrels is easy and quick. The fix usually costs a bit since most people bore the barrels to remove taper and must have new pistons and rings. Don't get into a habit of doing things just to "Check it out" or make sure it is right.
Old 2 Weeks Ago
randy3934's Avatar
where are you located? there are many members here that could have that bike running quickly. or at least recognize any problem it may have.
Old 2 Weeks Ago
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
This is the bike that was parked 8 months ago, right ?
As I said, there's usually a reason for a bike being parked like that.
If you have done at least a reasonable job with the compression test a "rule of thumb" will confirm what I am guessing has happened.
Instead of the compression tester just put a thumb over the spark plug holes and feel the compression generated. If one cylinder is really at zero it will be noticeably different.
The only times I have seen zero comp is with a holed piston. A very good reason to park a bike. It could also be a bent valve but in either case the head has to come off.
A leakdown tester will confirm if it's a piston or a valve problem.
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Ferrous Head
