0 WTB 04-06 intake manifold
Last Post: SportsterXLCH1967
Last Post: Rolschnee
0 1970 XLH Tach cable kinked
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 S&S Super B help
Last Post: Gravitas
0 Swing arm bearing change
0 2018 Iron 1275 Project
Last Post: yelladox
0 Homemade Lithium Battery
Last Post: t120r
Last Post: Firefight
0 1968 ex barn dweller thread
Last Post: fernf5
0 Swingarm Fitment
Last Post: Blacky
0 yost power tube guy
Last Post: cazz1000
0 S&S Super E
Last Post: CMCSSeabee
Last Post: Magneto Sportster
0 I made a oopsie
Last Post: robbie202
0 RIP Trainman
engine lift, k&l, lift gate, motor hoist, winch cable
Closed Thread
Old 2 Weeks Ago
ferretface's Avatar
Thanks for the link! Looks like a simple rig to fabricate.
Have you looked in the Sportsterpedia 'Tools' section to see if anyone has reviewed it??? Towards the bottom of this page -
http://sportsterpedia.com/doku.php/t...cal_categories
Old 2 Weeks Ago
Sportster/Buell Year: 1969
I like your work smarter not harder concept. However, being cheap like I am I would reinforce the 2x4 rafters and use the come along.
Old 2 Weeks Ago
AZbiker's Avatar
AZbiker AZbiker is offline
Sportster/Buell Model: xlh883
AZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud of
Originally Posted by ThenCameHarry View Post
Thanks for your reply.
5. It has to be USA made.
I got $20 that says that lift is not made in the USA.
Sent from my Moto E (4) using Tapatalk
Old 2 Weeks Ago
<snip>
Thanks again.
Best,
Harry
You're pretty much xxxxed on item 5. Made in downtown South Korea.
The San Jose facility seems to be where they un-crate and distribute the Korean products.
K&L products can purchased from hundreds of independent and franchised dealers throughout the United States and the World. Distribution centers are located in Santa Clara, CA, and new in 2015, a location in Atlanta, GA. K&L manufactures proprietary products through its facility in South Korea (K&L Supply Korea).
Begin again.
Ham, porkchops and bacon all come from the same magical animal?! That's crazy!
Old 2 Weeks Ago
Originally Posted by AZbiker View Post
I don't understand how this would be useful for removing and replacing a motor on any bike with a loop frame. All of them have to come in from the side.
have you read your factory service manual? yours should be the same.lift engine off the mounting pad slip engine from right side while tipping top of engine slightly off center of chassis.that's from my 2003 fsm. my 900 manual states install a spare engine bracket and with a hoist centered directly over engine attach a hook securely to bracket lift engine off the mounting pad then slip engine from left side of chassis top of engine tipped slightly toward center of chassis.
Old 2 Weeks Ago
mikethebike61's Avatar
When I needed to take apart the BMW (everything behind the engine) to do a clutch R&R I just hung a chain fall from the ceiling....
As stated by others...engine has to R&R from the side and if you do not want to lay the frame on the ground you have 3 options
1...have a VERY strong friend place engine in frame (BTDT)
2...place engine in frame without top end (that's what I do)
3...mini-fork-lift
Old 2 Weeks Ago
1. I am looking for a motor HOIST, not a bike LIFT. (Already have that.)
2. I don’t live in Texas.
3. The object is to put motor in the frame BY MYSELF any time if the day or night.
4. I do not want to spend more than $500 for a hoist that can do the job.
Thanks again.
Best,
Harry
That's not happening....
Old 2 Weeks Ago
ThenCameHarry's Avatar
ThenCameHarry ThenCameHarry is offline
Sportster/Buell Model: XLS
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1999
Other Motorcycle Model: Ironhead XLH
Other Motorcycle Year: 1979
ThenCameHarry has disabled reputation
Begin again.
Old 2 Weeks Ago
Begin again.
Sorry. When I said made in USA, I should have said not made in China.
I have no problems with products from South Korea. I have have had several lifts, wheel chokes, etc. from K&L and they have all been perfect.
Old 2 Weeks Ago
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
It never ceases to amaze me.
I ask a very simple question and get all kind of replies that have nothing to do with an answer to my question.
If I was interested in your thoughts on how to put a motor into a frame, I would’ve asked that question to begin with.
Over the years I have removed and installed several Ironhead motors. I’ve always done this using the laydown method. That has been very well explained elsewhere on this forum.
Works extremely well accept it requires more floorspace than I have available in the winter.
I asked a very simple question. Anybody out there that can actually answer it.
Much appreciated.
Harry
Starting a thread on a forum is like rolling a tire down a hill. You can’t control it once released.
I have never used that lift, but some similar types in an industrial setting. Limited in what it can do. It would be hard to maneuver with the load.
I’d just assume have a fold away “engine hoist”.
“Smooth roads, Blue skies and Green lights”
Closed Thread
