0 WTB 04-06 intake manifold
Last Post: SportsterXLCH1967
Last Post: Rolschnee
0 1970 XLH Tach cable kinked
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 S&S Super B help
Last Post: Gravitas
0 Swing arm bearing change
0 2018 Iron 1275 Project
Last Post: yelladox
0 Homemade Lithium Battery
Last Post: t120r
Last Post: Firefight
0 1968 ex barn dweller thread
Last Post: fernf5
0 Swingarm Fitment
Last Post: Blacky
0 yost power tube guy
Last Post: cazz1000
0 S&S Super E
Last Post: CMCSSeabee
Last Post: Magneto Sportster
0 I made a oopsie
Last Post: robbie202
0 RIP Trainman
engine lift, k&l, lift gate, motor hoist, winch cable
Closed Thread
Old 2 Weeks Ago
ThenCameHarry's Avatar
ThenCameHarry ThenCameHarry is offline
Sportster/Buell Model: XLS
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1999
Other Motorcycle Model: Ironhead XLH
Other Motorcycle Year: 1979
ThenCameHarry has disabled reputation
Originally Posted by Maxeffort View Post
Starting a thread on a forum is like rolling a tire down a hill. You can’t control it once released.
I have never used that lift, but some similar types in an industrial setting. Limited in what it can do. It would be hard to maneuver with the load.
I’d just assume have a fold away “engine hoist”.
Thanks so much for your reply.
It’s not a lift though. It’s a lift GATE. On that I hang a winch manually operated.
How do you know it is hard to maneuver with a load?
So apparently you have used one and found that out, right?
Thanks again,
Harry.
Old 2 Weeks Ago
ferretface's Avatar
Originally Posted by ThenCameHarry View Post
I ask a very simple question and get all kind of replies that have nothing to do with an answer to my question.
I would think that is better than a mean forum member taking offense to your attitude and deliberately giving you incorrect information.
I was interested in reading brucstoudt's quote from the 900 FSM about using a spare engine bracket to lift the engine. My 1985 FSM doesn't have that but it should still work. I've added that to my personal Tips & Tricks list.
It's off-topic replies like that that can save time or money or skin...
Old 2 Weeks Ago
$450? I will pay that much including the manually operated winch.
Rollers tend to be troublesome. After reading all kind of reviews.
If I put the gate on a piece of carpet and I suspect it will slide just fine.
The way I have it all set up next to my frame on a K&L lift it won’t need to slide more than a few inches.
At least that is what I think it will do. I had hoped to hear from somebody that has actually use this lift-gate and this particular winch. I suspect I’m not gonna find anybody.
Thanks.
Old 2 Weeks Ago
i fabricated one from flat bar.i was concerned about damaging my 1960 oem part pulling on an angle.
Old 2 Weeks Ago
Maxeffort. the overhead gantry is a design with multipule uses. my dad built one for 2 of the the garages he owned.unfortunately to pull an XL motor from it's frame you need to pull on an angle which having a trolley on wheels would make it difficult without counter measures.
Old 2 Weeks Ago
AZbiker's Avatar
AZbiker AZbiker is offline
Sportster/Buell Model: xlh883
AZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud of
Sorry. When I said made in USA, I should have said not made in China.
I have no problems with products from South Korea. I have have had several lifts, wheel chokes, etc. from K&L and they have all been perfect.
I am in 100 percent agreement with this.
I am not old enough to remember what happened at the Chosin Reservoir, but I sure know what happened there. China is an enemy of the United States.
Kudos to you for trying to avoid buying goods manufactured there.
Sent from my Moto E (4) using Tapatalk
Old 2 Weeks Ago
Originally Posted by azbiker View Post
i am in 100 percent agreement with this.
I am not old enough to remember what happened at the chosin reservoir, but i sure know what happened there. China is an enemy of the united states.
Sent from my moto e (4) using tapatalk
mikethebike61's Avatar
Probably better than the H/F thing I have.....but it suits my needs at age 72...
ferretface's Avatar
Wal-Mart has the lift gate for $275...
K&L Supply Lift-Gate 35-9940 $275.27
https://www.walmart.com/ip/K-L-Suppl...9940/358925521
  #30
Right. But no winch.
Closed Thread
