0 What Is the Advantage - Shovster?
Last Post: XL-Novice
0 Swing arm bearing change
Last Post: SportsterXLCH1967
0 final drive front sprocket change
Last Post: lostNdallas
0 xl1200T
Last Post: luce26
Last Post: Maxwell#256
0 Backfiring
Last Post: David Kirkha
Last Post: rocketnorton
0 S&S Super E
Last Post: Serious Blac
0 Iron 2020 wire tuck
Last Post: Dorretje
Last Post: SLW210
0 1970 XLH Tach cable kinked
0 Swingarm Fitment
Last Post: SLW210
0 WTB 04-06 intake manifold
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 S&S Super B help
engine lift, k&l, lift gate, motor hoist, winch cable
Closed Thread
  #31
ferretface's Avatar
ferretface ferretface is online now
Originally Posted by ThenCameHarry View Post
Right. But no winch.
Odd that it has the same K&L stock number...
I went to K&L's web site and punched in 35-9940, and got the Lift-Gate page. With the message "Winch Sold Separately"...
https://www.klsupply.com/shop-lifts/k-l-lift-gate.asp
  #32
AZbiker's Avatar
AZbiker AZbiker is offline
Sportster/Buell Model: xlh883
AZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud ofAZbiker has much to be proud of
The winch is a separate part number. I hate it when they do that.
Sent from my Moto E (4) using Tapatalk
  #33
mikethebike61's Avatar
2x4's and a piece of unistrut and a chain fall and you're done
  #34
ThenCameHarry's Avatar
ThenCameHarry ThenCameHarry is offline
Sportster/Buell Model: XLS
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1999
Other Motorcycle Model: Ironhead XLH
Other Motorcycle Year: 1979
ThenCameHarry has disabled reputation
Just some more grandstanding BS
  #35
XL Ed's Avatar
XL Ed XL Ed is offline
XL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond reputeXL Ed has a reputation beyond repute
Dude you are making tis way harder than it has go be. You are lifting the whole bike. Just part. Maybe 350 to 400 lbs at the most. People are just trying to help. If you really just want what you want then buy it but done waste our time and yours asking a question you already know the answer to.
  #36
Roscoe13 Roscoe13 is offline
Sportster/Buell Model: XLH883
Roscoe13 has a brilliant futureRoscoe13 has a brilliant futureRoscoe13 has a brilliant futureRoscoe13 has a brilliant futureRoscoe13 has a brilliant futureRoscoe13 has a brilliant futureRoscoe13 has a brilliant futureRoscoe13 has a brilliant futureRoscoe13 has a brilliant futureRoscoe13 has a brilliant futureRoscoe13 has a brilliant future
Somewhere along the line someone should have advised you that you attract a lot more flies with honey than vinegar...
  #37
Blah blah blah blah blah blah blah
  #38
leon bee leon bee is offline
Sportster/Buell Year: 75
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 74
Other Motorcycle Model: BSA
leon bee is a glorious beacon of lightleon bee is a glorious beacon of lightleon bee is a glorious beacon of lightleon bee is a glorious beacon of lightleon bee is a glorious beacon of lightleon bee is a glorious beacon of lightleon bee is a glorious beacon of lightleon bee is a glorious beacon of lightleon bee is a glorious beacon of lightleon bee is a glorious beacon of lightleon bee is a glorious beacon of light
I just grab the goddam thing with my bare hands and pull it out on the floor.
  #39
Well, if you're so damned smart......why aren't you designing a solution to YOUR problem
When i needed to lift the back of a 625lb BMW for a clutch R&R I just mounted a load rated U bolt to a 2x4 lag bolted to the ceiling and hung a chain fall
But, hell, you must be insanely more intelligent than i for you are making it much more complex than some dumb 72 year old with 60 years experience with cars, motorcycles and sailboats could ever contemplate.
Enjoy your self proclaimed purgatory....
  #40
72 ?????
Well, young man, I have roadkill in my freezer older than you are. Ha ha.
Closed Thread
