0 WTB 04-06 intake manifold
Last Post: SportsterXLCH1967
Last Post: Rolschnee
0 1970 XLH Tach cable kinked
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 S&S Super B help
Last Post: Gravitas
0 Swing arm bearing change
0 2018 Iron 1275 Project
Last Post: yelladox
0 Homemade Lithium Battery
Last Post: t120r
Last Post: Firefight
0 1968 ex barn dweller thread
Last Post: fernf5
0 Swingarm Fitment
Last Post: Blacky
0 yost power tube guy
Last Post: cazz1000
0 S&S Super E
Last Post: CMCSSeabee
Last Post: Magneto Sportster
0 I made a oopsie
Last Post: robbie202
0 RIP Trainman
alternator
BigMek's Avatar
BigMek BigMek is offline
Sportster/Buell Year: 1982
BigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond repute
When you measured the regulator resistance, did you do it off the bike like the instructions say to? Have you verified the regulator has a good connection to ground?
Helldriver Helldriver is offline
Sportster/Buell Model: Ironhead XL
Helldriver is an unknown quantity at this point
I took a reading off the bike. The instructions were a little confusing but I figured since it was looking for a measurement in ohms, I set It to the ohmmeter.
I have read that I should Be checking the diodes on the diode setting though.
The ground I had it attached to while it was on the bike was good. I verified It with my multimeter.
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
In the diode setting, the meter supplies a DC voltage to forward bias the diode. The reading on the meter display will be in DC volts. Usually around .6 VDC for one diode.
“Smooth roads, Blue skies and Green lights”
Maxeffort's Avatar
At this point, I’m assuming the regulator/rectifier is shot.
But the alternator is functioning and the installed washer is preventing the oil from seeping.
Is there a preferred regulator/rectifier anyone would suggest?
V-Twin list the replacement as # 32-0667
Got it all sorted.
Checked the diodes on the regulator/ rectifier and they were bad.
The supplier said they’d replace it for a new( functioning) one.
I pulled a thread or two out of the alternator taking it in and out to check clearance in the washer. I was Able to helicoil the alternator and mount it with no issues.
I appreciate all the advice.
