Last Post: BestCoastXL
0 What Is the Advantage - Shovster?
0 WTB 04-06 intake manifold
Last Post: SportsterXLCH1967
Last Post: Rolschnee
0 1970 XLH Tach cable kinked
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 S&S Super B help
Last Post: Gravitas
0 Swing arm bearing change
0 2018 Iron 1275 Project
Last Post: yelladox
0 Homemade Lithium Battery
Last Post: t120r
Last Post: Firefight
0 1968 ex barn dweller thread
Last Post: fernf5
0 Swingarm Fitment
Last Post: Blacky
0 yost power tube guy
Last Post: cazz1000
0 S&S Super E
Last Post: CMCSSeabee
Last Post: Magneto Sportster
0 I made a oopsie
Last Post: robbie202
Monte03's Avatar
Monte03 Monte03 is offline
Sportster/Buell Year: 1969
Other Motorcycle Year: 82
Default Piston Hit Intake Valve
No the Valve did not get stuck in the guide, tell me all the scenarios where an 1-15/16" R valve can contact a Piston..Go >
Cycle World Oct 1962:
sungod's Avatar
sungod sungod is online now
Sportster/Buell Model: sportster xlch
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 73
sungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to allsungod is a name known to all
Default Ironhead piston
A couple of clearance issues come to mind like quish and radial clearance to valve pocket too small.Weak valve springs at high rpms can loose control of the valve. Carbon buildup in a tired cylinder.Is this happening in a new build?
shanneba shanneba is offline
Over rev floating valves
Broken valve spring
Spring collar broke- or the keeper came out
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
sungod's Avatar
More scenarios include wrong timing,worn bottom end and piston/cylinder overheating.
Can you give more info?
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
piston installed reversed
kitabel kitabel is offline
Sportster/Buell Year: 1989
What was the last thing you changed before this happened?
BigMek's Avatar
BigMek BigMek is offline
Sportster/Buell Year: 1982
BigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond repute
Flywheel pinion shaft not timed to the rest of the valve train would do it. Made that mistake myself once.
While building my 4 and 5/8's stroker I sent heads off to have seats installed, valves and springs. Of course I upgraded my 900 heads to 1000 valves. The SIFTON Titan cams are not an exceptionally high lift but I clayed the front piston valve pockets when I went together and found the engine would not turn over. The S&S pistons had to have the intake valve pockets flycut to create enough clearance. Engine building 101.
900 pistons or 1000? domes are different.
Mine are 3 inch 40 over. 900
