0 Stacking the Alto Carbonite clutch !
Last Post: Bikeaholic
3 Shaky Dave Recovery
0 spark plug wire ohms
Last Post: Kbetts
0 Finally Got the Kinks Out
Last Post: Proteus
0 2.18 Gearing Ratio For 5 Spd 1200??
Last Post: vagrant318
0 Getting ready to try firing it up after a year long rebuid
0 Head bolts and conversion
0 Alarm Time Out?
Last Post: brixtonanima
0 Finding an accessory power source
0 1972 XLH question
Last Post: 1Scooter
Last Post: marksfatboy
0 Rocker cover torx
0 FS: Forward Controls (2004 - 2013 Sportster)
Last Post: wrkdWS6
0 my recent ebay purchase
0 Who Runs Turn Signals?
Last Post: Tincan
0 '86 1100 basket build
0 Stretched Swingarm
Last Post: Racepres
0 cleaning method for cases
0 Is static timing enough?
Last Post: ccmman
0 Changing engine oil
0 su carb question
View Poll Results: The 04/05 Screamin' eagle A/C is a peice of crap
I agree 226 30.42%
I disagree 135 18.17%
I dunno yet, but I'm gunna waste my money and try it 116 15.61%
I dunno, but I ain't gunna waste my money findin' out 252 33.92%
I'm a Doofus! I rejected the advice, bought one..and now its a piece of crap. DOH!! 14 1.88%
Voters: 743. You may not vote on this poll
Old 29th April 2005
thunderpaw's Avatar
thunderpaw thunderpaw is offline
thunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the roughthunderpaw is a jewel in the rough
Default Another afflicted SE A/C setup
I read with interest about the problems many of you had with your SE air cleaner developing holes in the filter medium, as well as Gronk's experience with a warped backing plate.
When removing my SE setup to put on the Big Sucker and round cover, I noticed that I, too, had both the pinholes and the warped backing plate. I am steamed!
When I get back, I will contact Harley and, fully expecting to be 'blown off' by them, request that they provide me with dealer credit for the cost of the SE kit. I don't want a replacement of that POS!
Kim
I didn't buy a Sportster because I wanted a Harley....I bought a Harley because I wanted a Sportster.
Old 29th April 2005
scooter's Avatar
scooter scooter is offline
scooter has disabled reputation
Yeah....I notice my S/E A/C backing plate was a little warped when I took it off to install the Ness A/C. I looked at the filter and it didn't have any holes in it.
Keep us posted on what you find out.
Old 29th April 2005
invaliduser invaliduser is offline
invaliduser has disabled reputation
Where did you guys purchase the Big Sucker? Was it the model for the sportster and is it round? Every place I have found it, it says the oem cover will fit, I assume it is the round oem that will fit.??
Old 30th April 2005
Bill2's Avatar
Bill2 Bill2 is offline
Sportster/Buell Model #2: XL standard 883/1200 conv
Bill2 has disabled reputation
You can add one more to the growing list. Mine is maybe 2 months old, took it off today and full of holes. I sure don't want a replacement POS. Anybody using a dragtron 2 air filter? Thinking about ordering one. There round and the filter is encased in a heavy stainless steel mash. They look good!
'05 Standard 883/1200 touring conversion with: '07 XB heads with 8.8:1 c/r, dragtron II a/c, Caliber 2into1 five step header, rejetted to: 46pilotjet @ two turns,needle clip on 4th groove,185 main jet,twin tech high performance ignition, 30 tooth trans pulley, jagg oil cooler, forward controls, pullback type handle bars,memphis fats windshield, Corbin classic solo seat with back rest, 10" pillion pad, black progressive 412 shocks 12.5" H-D springs, progressive fork springs, vista cruise control, and relocated ignition & coil to a stainless steel home brewed mount between the cylinders. (Temp. runs around 165-180 degrees in town and 180- 210 degrees on the freeway running 70-90mph and it uses no oil in between 3000 mile changes.) GPS calibrated speedometer.
Old 30th April 2005
xena's Avatar
xena xena is offline
Assistant Administrator
Sportster/Buell Model: 1212 conversion/497 cams
Add me to the list. Mine was hole city after just 2k miles. I don't want a replacement either, but would be interested in hearing what they tell you Kim.
I forgot to add that there was also about two tablespoons worth of oil sitting in the bottom of my SE AC when I removed it to install the round btwin ac.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams, E1 clutch, Python 3 Slip ons
TC88A running Xena's (brand new) White Tiger Map
My 1212 Conversion Thread
Old 30th April 2005
gronk62's Avatar
gronk62 gronk62 is offline
mostly harmless.. (sssm)
gronk62 has disabled reputation
I wonder how we would best go about bringing this to HD's attention.
Its obvious these are not just isolated incidents..the 04/05 sreamin eagle air cleaner is a total peice of crap!
I don't want a replacement for mine either..but it would be nice to get the $280 back that I payed for this rubbish.
Yep thats how much we pay for 'em down under
The thing I really want the most is to help prevent any more of our Sportster riding brothers and sisters wasting their money on this junk in the first place.
If sales drop dramatically maybe HD will pull their heads outa their arse and take notice, and hopefully dramatically improve the quality.
The pre 04 SE A/C's were a great product. Bring 'em back I say!!
Old 30th April 2005
gronk62's Avatar
I'm gunna make this thread "sticky" for a while in the hope newbies will read it before they make their stage 1 purchase's.
Old 30th April 2005
maddog's Avatar
maddog maddog is offline
Sportster/Buell Model: Hugger 883/1200
maddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura about
I used it for a while then sold it to my buddy when I got a Doherty Machine A/C. I liked it and my buddy loves it.
A word of warning though. Don't use the wire mesh/foam element that comes with it. It doesn't breathe very well. Replace it with a K&N lifetime element. The Drag Specialties Catalogue has them listed together.
Night Train + Street Fighter= NIGHT FIGHTER
MY GALLERY
"It's just a Sportster, but I'm saving up for a Big Twin."
That's like saying...
"It's just a Corvette, but I'm saving up for a Station Wagon."
STEPHANIE FELD
HOT XL MAGAZINE
SUMMER '97
He was asked, "Why do you ride?" He considered the question carefully for a few moments. "The Lean", he replied.
Old 30th April 2005
maddog's Avatar
Gronk..I keep hearing about these 'stickies' but I can't find'em. Where do they get put?
Thanks..Jim
Old 30th April 2005
gronk62's Avatar
Thanks..Jim
They are threads that stay at the top of each forum area so they are easy to find without having to do a search.
Here is an example.
Similar Threads
Sound difference between SE slip-fit torque mufflers and SE Pro II slip-fit mufflers gardkarlsen Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 8 4th July 2008 20:31
Experts: 'SE' or N4 cams for a stock 04 XL1200? Turbota Sportster Motorcycle Motor - Top End 12 14th August 2006 13:08
new number and higher price for se high flow donna Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 9 6th April 2005 05:38
putting SE AC on CA Bike Scarecrow2311 Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 3 22nd February 2005 05:14
FXSTB 'Night Train' SE Aircleaner Install (pics) Turbota Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 15 26th November 2004 03:06
