0 LED Brake light, surprising problem
Last Post: deuce460
Last Post: deuce460
Last Post: deuce460
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: 1mellom8
0 Some oil issues!
Last Post: debster
Last Post: Clevspeed
0 Jockey Shifter on a Right Side Shift Bike?
Last Post: dodgetrucken
0 Manifold -CYLYNDER head connection
Last Post: shooterj2003
0 XR front rocker box needed
Last Post: Scott
Last Post: Scott
0 Selling my Sporty...
Last Post: Mr. Rossi
10 New to the HD world, Ironhrad vs Shovel, whats the diff
Last Post: motorend
10 howdy from australia
0 I guess I'm back
Last Post: jcn59
0 Should I buy a Sportster??
Last Post: Hopalong48
0 Hello from mid Missouri
0 Mystery drip off rear brake cylinder
Last Post: BluesandBike
0 .551 Cams in an EFI 1200
Last Post: SLW210
0 1991 frame/engine original ground locations
0 Born Free bike show
Last Post: smokey 2
0 Rocksett
Old 22nd February 2019
rog rog is offline
Sportster/Buell Model: XL883
Sportster/Buell Year: 1986
rog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura about
Default Hard to shift
Hey,
I just broke open the primary case on an XL883 1986 to replace the clutch cable. I am using forward controls. Since doing so, I am having trouble changing up, it has become physically difficult and hard on my foot! The clutch feels perfect, and the bike stands still with clutch engaged, and it lets out nicely with no slip when power applied. The clutch adjuster is adjusted to its first range, and by winding it open it becomes slippy and the clutch becomes less responsive. Any ideas of what I may have changed that creates the issue?
Thanks, Rog.
Air-Cooled Forever
What type of 'Forward controls' are you using? Factory, aftermarket brand or home-made?
Some of the aftermarket brands seem to have their leverage points "off" slightly making them harder to shift and some are so loose they rattle and over-tightening them is common. Sometimes, just lubing the joints with motor oil will make them shift a lot better.
Old 23rd February 2019
rog rog is offline
Fixed her! When I put the gear change back on I had moved it a couple of degrees off from where it was. The shifter position felt the same but it wasn't able to get full leverage up. Moved it on the spline and hey Presto!
Air-Cooled Forever
Good to hear. Been there, done that!
