0 Another Sporty ADV Build
Last Post: 51 New West
5 What Color Helmet is Most Noticable?
0 my rear wheel
0 Friction modifiers in gasoline
0 Adding fuel level sensor to the speedo/tach
0 Delete rocker box breathers or not?
0 clutch spring compressor
0 A Day in the Life...
Last Post: RDHenley
0 quick shifters
Last Post: gusm2
0 How much is too much?
0 Ironhead Oil Pump Gurus, come inside.
0 1976 Ironhead Top End Rebuild
0 520 conversion for ironheads
0 1960 XLCH in the UK
0 Trying to trace a seat part number ...
Last Post: neilp
0 Mid or forward controls.
0 Your Motorcycle Workspace/Garage
Last Post: duffy
Last Post: scooby
0 Sportsterpedia Progress
steve yorke (62), edman (54), Hudsonator (52), kozman32 (52), R3DN3X (50), gmcsid (49), mitch (44), Txngrg87 (33), Gotenfan (30)
Old 6th May 2011
DIESEL's Avatar
DIESEL DIESEL is offline
Originally Posted by RKN View Post
Thanks for telling! That's way cheaper than $600. How's the clutch lever compare to stock 883 - is it much harder to press?
Yes, until it gets broken in. I have 3 bikes and don't notice any difference now. When it was first installed, yes, major difference.
If you are not going to do the install yourself (which is easy cheesy) then you don't need the kit with the tool. You do NOT have to remove the basket or Primary Chain. Just pull the primary case, use tool, remove old plates, install new parts, and button her back up.
Old 6th May 2011
xHDrider's Avatar
xHDrider xHDrider is offline
Sportster/Buell Year: 1991
Other Motorcycle Model: 650 Triumph Bonneville
Other Motorcycle Year: 1970
xHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of lightxHDrider is a glorious beacon of light
I'm running the heaviest clutch spring I could find on the internet. its not a bad pull until you drive in town then it sucks.
I live in the sticks
883 / 1200 conversion, shrink ported high velocity heads, milled .020 off the compression side. stainless steel tulip conversion valves. 10:1 wiseco forged pistons. "W" cams, Crane HI-4E ignition module, forcewinder AC. mustang seat, Progressive springs, RK-shocks, fork brace. metzeler me880 tires, headlight modulator. PIAA intense white H4 bulb
Old 6th May 2011
RKN's Avatar
RKN RKN is offline
Sportster/Buell Model: 883 (90")
Sportster/Buell Model #2: 5" stroker in progress
Other Motorcycle Model: 900 CH engine in H frame
Other Motorcycle Year: 196?
RKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to allRKN is a name known to all
Talked to my mechanic today - I'm gonna order it. Hope it'll get broken in fast, because 80 % of the time I do ride in the city.
Old 6th May 2011
cowboy770's Avatar
cowboy770 cowboy770 is offline
cowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of lightcowboy770 is a glorious beacon of light
[QUOTE=shaymus;3267070]Mine was the same way. I replaced everything in the clutch and it still slipped. So, $600 later I got a Barnett racing clutch.
[/Q
How hard was it to put in? Did make a big change it the feel of the clutch? Was it worth the money?
Strangeman of the Gas Guzzlers MC
04 1200R N4 cams, custom A/C , stage 1 P&P, porker switchblades, Tc88a with Ricos Hooligan map, 185 main, 48 slow, and custom 5.2 gal tank. 3-1/2in extended forward controls, Enough about me, tell me about you.
Old 8th May 2011
shaymus's Avatar
shaymus shaymus is offline
Sportster/Buell Model: Sportster 1200 .030
Sportster/Buell Year: 1987
shaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of light
[quote=cowboy770;3270925]
[/Q
Just got it the other day. I'm going to put it in tomorrow. Untill I can get my bike to start ( which I've been going through hell ), I won't know. I replaced everything with the stock clutch which cost me around $1000 and it still slipped. That is why I bought the drag racing clutch. I just hope I can pull the lever. It came with 3 sets of springs , I put the med. in and it says they are 70 lbs. I probably will get a popeye arm out of it. As for putting it in , the direction look pretty simple. I goes in the stock clutch basket.
Old 8th May 2011
xHDrider's Avatar
[quote=shaymus;3272698]
let us know how this works out for you. what kind of torque are you putting to to the ground with your engine?
I had to adjust my ramp adjustment to 3/4 turn backed off to help pervent slipping. 1/2 turn still slipped. thats with 1/8" cable play. (after take-up)
some times I wonder if the ramp assy should have its own return spring.
I hate a slipping clutch. (all with an extra-plate clutch and competition clutch spring) I'm even running spectro lube in the chain case / transmission
Old 12th May 2011
RKN's Avatar
RKN RKN is offline
Ordered Belt Drive clutch from Dan at NRHS. Intersting, the problem I described (0.5...1 sec delay after releasing the clutch lever) doesn't happen all the time. Could it possibly be that the clutch cable needs lubricating?
Old 12th May 2011
xHDrider's Avatar
it could be the cable, or maybe the ball has worked a little pocket in the ramp assy.
I think the ramp lever should have a return spring on it. (they don't come with a spring)
