10 howdy from australia
0 Hello from mid Missouri
0 LED Brake light, surprising problem
Last Post: deuce460
0 Throttle Cable Adjustment Question
Last Post: deuce460
0 Sportster in custom softail frame
Last Post: deuce460
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: 1mellom8
0 Some oil issues!
Last Post: debster
Last Post: Clevspeed
0 Jockey Shifter on a Right Side Shift Bike?
Last Post: dodgetrucken
0 Manifold -CYLYNDER head connection
Last Post: shooterj2003
0 XR front rocker box needed
Last Post: Scott
Last Post: Scott
0 Selling my Sporty...
Last Post: Mr. Rossi
10 New to the HD world, Ironhrad vs Shovel, whats the diff
Last Post: motorend
0 I guess I'm back
Last Post: jcn59
0 Should I buy a Sportster??
Last Post: Hopalong48
0 Mystery drip off rear brake cylinder
Last Post: BluesandBike
0 .551 Cams in an EFI 1200
Last Post: SLW210
0 1991 frame/engine original ground locations
0 Born Free bike show
Last Post: smokey 2
0 Rocksett
Old 19th May 2011
chardhin's Avatar
chardhin chardhin is offline
Sportster/Buell Model: xl 883c<1212
Other Motorcycle Model: RoadKing Classic
Other Motorcycle Year: 2010
chardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond repute
Default primary parts numbers info needed!!
Ok, I am gonna go ahead and change my primary pulleys and chain from (year 2005) 883 to 1200. I have a parts book but its 1500 miles away. I am trying to order these parts while I am away as to have them ready when I return to tulsa. What I am asking is what are the parts numbers so I can order them from chicago Harley. I would need both 1200 primary pulleys, 1200 primary chain, the gasket for the primary case. If I am missing anything else please inform me. I am thinking of doing a Barnetts clutch as I am in there but not sure which one to go with, any advice? thanks members, your advice is greatly appreciated
I find it hard to believe that "everybody" was Kung Fu fighting.
Old 19th May 2011
There's a sticky on site that allows you to get all the numbers you might need. If for some reason it's not availible go to "Bike Bandit.com" They'll have schematics and numbers to cross reference. Good luck. you've already learned that the 1200 Rubbermount crank gear is 4 tooth larger.
Old 19th May 2011
chardhin's Avatar
thanks paul, I will look for the sticky.
Old 19th May 2011
chardhin's Avatar
haha! I couldnt find the sticky and bike bandit doesnt have the parts. they have a great breakdown but these specific parts they dont have listed. just my luck. do you have a link to the sticky?
Old 19th May 2011
chardhin's Avatar
well they had the pulley parts numbers but not the chain.
Old 19th May 2011
Cosmo Kramer-19 March 2011, Sportster Motorcycle General Discussion and Problems, "How to view H.D. part #'s 1991-2010, all models with part numbers and exploded views. Should be the seventh one down. Could also do a search under Cosmo's threads. That should do it for you. Best of luck cause I went through Hell last summer getting a primary for my '06 1200. Most everybody including the dealers didn't know Harley made the change with the 1200 Rubbers.
Old 19th May 2011
chardhin's Avatar
and there is the stickey. I was looking in the primary/transmission area. thanks a lot, have some rep for your help!!
Old 19th May 2011
chardhin's Avatar
I got the part numbers now. But do I need to buy the sprocket and rotor as one piece, or just the sprocket? I question this because when I looked it up between bike bandit and the link on cosmos sticky, the stickey didnt show a difference between the two sprockets, and bike badit does but sells both. so I am a little confused.
Old 19th May 2011
Either sprocket will bolt up to your existing rotor, the mount holes are the same, just the change in tooth count.
Old 19th May 2011
chardhin's Avatar
sweet, that is great. somewhat cheeper that way. gonna order parts tomorrow, thanks again.
