Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > FORUM FUNCTIONS > Forum Announcments/FAQ/Suggestions/Test > Forum FAQ/HOW TO
Forum FAQ/HOW TO Facts Answers Question about the Sportster Forum and how to use the forum funtions
0 New member
0 Roadster CX Cafe Build
14 Mid controls??
Last Post: Nicktree1200
0 Best Street/track Camshaft for boost, help??? :)
Last Post: Jens L
Last Post: SLW210
0 Frame bracket
Last Post: Bwf347
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
Last Post: ZCarFan
0 Headlight help please
Last Post: PetesPonies
Last Post: TUCCI
0 tire changer
0 Ve tables for iron 883 with 1250 conversion
Last Post: Bikeaholic
0 su carb question
0 Why cafe a sportster?
Last Post: TUCCI
0 New to the Chopper Lyfe
Last Post: Bigshankhank
0 Anyone put a mechanical speedo drive on the rear wheel?
Last Post: xl883lo
0 Wtb--1967--1972 xlh
Last Post: Doc308
0 new to me 883
Last Post: Racepres
0 Getting ready to try firing it up after a year long rebuid
Last Post: nychopper
0 Akrapovic Open Line exhaust
0 Tachometer?
fhilliard (79), paulmo (75), Beloved (49), Mr. Cro (49), Chopper Duke (41), Danny3nose (39)
Closed Thread
Old 8th September 2011
steelworker's Avatar
Other Motorcycle Year: 2016
Default Got a problem? Need help? OK, but help us first.
This thread rehashes a lot of what has been said in chrishajer's old thread "Suggestions for maximizing the amount of help you receive", but it bears repeating, as it's obvious that a lot of people don't read that before posting.
A lot of us here like to help out with advice wherever we can, but it's not helped by threads with titles like "Need Help! Now!!!"; vague and incomplete descriptions of symptoms; no indication as to what model we're looking at; etc. Getting sufficient information out of people who have a problem with their bike is too often like getting blood out of a stone.
The following information makes life a lot easier:
1. Fill out your profile with your Sportster model and year. If you have more than one Sportster listed in your profile, make it clear in your post which one you're referring to.
2. Post your thread in the relevant section:
Motor - Top End / Bottom End
Intake / Exhaust
Electrical and Ignition / Lighting
Transmission
Tires, Wheels & Brakes
Suspension, Frame, Forks, …
... or, if you can't narrow it down, post in the General Discussion and Problems section
3. Give your thread a clear, descriptive title (i.e. not "HELP!!!!") and, if you think it's relevant, use the prefix option on the thread starter to indicate Ironhead, Rigid EVO, Rubbermount EVO or Rubbermount EFI.
4. In your post, give as full a description as possible of the problem and all symptoms, and under what conditions the problem manifests itself.
5. List any work that has recently been done to your bike, and any parts recently fitted or changed. Problems don't always just happen. They are often related, directly or indirectly, to the last thing that was done to the bike; so knowing the recent history can help a lot in diagnosing what is, or what may, be wrong.
6. If your bike has modified or non-stock parts fitted (e.g. carburretor, exhaust, wheels, brakes, etc) that may be relevant to your post, then say so.
7. If you have already carried out some checks / tests, state what you did and the results.
And finally, if you fix the problem and get the bike running again, please take a moment to let us know before you ride off into the sunset. We need closure.
Flame__'s Avatar
Flame__ Flame__ is offline
Artist, rider, wrencher
Sportster/Buell Year: 1989
Sportster/Buell Year #2: 1988
Other Motorcycle Year: 2000
I would like to add; Include your location in your profile!! There are members who would be willing to ride over and help, if we just knew where the hell you are!! You don't have to put a street address, Just a country and state will do! And post a pic! Sometimes a problem can be spotted that you didn't catch!
Knees in the breeze.
Gamertag, PS4: Bikerdude__
hmiller's Avatar
hmiller hmiller is offline
Sportster/Buell Model: 883
Other Motorcycle Model: BMW K1200GT
hmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud of
Amen to that! There's nothing worse than no closure. A lot of times the search feature doesn't help because you read through 30 pages of diagnosis then.......nothing!
ColinB ColinB is offline
Sportster/Buell Model: 883R
ColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond repute
Excellent post - but if I can add to the above, please. A short clear title can only say so much, but then the first few sentences also should be very descriptive of the problem also.
I hovver my mouse over any title that interests me and get the first few sentences of the post - and if that doesn't 'draw me in' then I move on.
This means that a poor title with some rambling few starting sentences will never get a look in from me.
SuicideCharley's Avatar
SuicideCharley SuicideCharley is offline
Bike Builder
SuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to allSuicideCharley is a name known to all
+1 on the above. I would also add:
*LOCATION LOCATION LOCATION - Add your location to your info. Someone may be near by that can assist. Live Local Late Beaking assistance is awesome.
*Be open to suggestions - Don't be dissmissive to folks, others may not help if they feel like you aren't open to their suggestions. People are trying to help nothing more, and that's what makes this place
Old 10th September 2011
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Great post Myles! And good suggestions from the others too.
Folkie
South East England Riders
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
EXACTLY what I thought Nigel!
Great post Myles! MAYBE it'll help someone understand and get the help they need/want!
Stuff: YES
Folkie's Avatar
Brass Nut
Hey Myles, I hope you don't mind: I made the Forum sections in your post into links. Made the thread a sticky too.
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Myles look at that, your Thread is sticky...try WD-40.
Thanks Nig, the links are good. And thanks for the stickiness.
Closed Thread
