12th April 2011
No Posts
Setting Timing w/ Electronic Ignition
My 1973 XLCH was converted to electronic ignition. It starts great ..hot or cold...but seem a little sluggish on the top end. I have the timing set to the rear cylinder dead on the double dots. Not sure if it should be advanced or what? Can it be set using a dwell meter??? Or is the timing mark setting adequate. I plan on chaging out the mechanical advance because not sure the old one is working as well as it should. The counter weighs seem to be free and functional...but not sure it is working at the higher rpms. Can anyone help or provide some advise.
13th April 2011
Posts: 1,165 Sportster/Buell Model: XLH Sportster Sportster/Buell Year: 1991 Other Motorcycle Model: 650 Triumph Bonneville Other Motorcycle Year: 1970
time it the same way you would if it had points. unless the unit advances its self with out the weights moving. (we would need more info) I like the dial back timing lights using the TDC marks.
883 / 1200 conversion, shrink ported high velocity heads, milled .020 off the compression side. stainless steel tulip conversion valves. 10:1 wiseco forged pistons. "W" cams, Crane HI-4E ignition module, forcewinder AC. mustang seat, Progressive springs, RK-shocks, fork brace. metzeler me880 tires, headlight modulator. PIAA intense white H4 bulb
