0 93 Sporty Key replacement
0 Mid West Meet & Greet
Last Post: Bow only
0 Rear Rocker Gasket Blown
0 4 Speed Stator Replace
Last Post: connorneil13
0 Pics of your significant other
Last Post: rocketnorton
0 Huge pile of Ironhead Parts
5 1969 XLCH exhaust question
0 Should I buy a Sportster??
Last Post: Medyo Bastos
0 Generator removal
0 Lifters Comparison
0 Simplified Wiring and Bars
0 compression low?
0 Spark plug discrepancy
Last Post: Ted Town
0 I'm back...
Last Post: Reverend G
0 1967 Harley Sprint SS250
Last Post: Crash7557
0 mixing brake parts
Last Post: Clevspeed
0 Mid or forward controls.
0 ultima electronic ignition
Last Post: rich56
electrical problems
Old 20th May 2019
Originally Posted by xElvis View Post
Appreciate the feedback.
The lights work, sort of. They are powered, and running fine. I hit the signal button, no blinking, but the running ambers stay lit. I hit the brake, the tail light doesn't go extra bright, but DOES stay lit normally. For this reason, I've ruled out fuses / relays. The lights work, but the controls aren't registering. Because of short in controls, or the TSM computer, as best remaining culprits.
Those working circuits DO NOT USE THE ACCESSORY FUSE - those circuits are powered by the LIGHT FUSE...
You have not eliminated the possibility of the fuse being blown or there being other defective connections on the ACCY Circuit...
Old 20th May 2019
xElvis's Avatar
xElvis xElvis is offline
Sportster/Buell Model: XL883
xElvis has disabled reputation
Huh ... my thinking is too simple for those electronics ... I knew it. Ok. I have spares, will toss one in and report back.
I hate dealing with electronics and my ignorance shows it.
xElvis - DOT Certified Cage-Free - '08 883 ~100k miles
Old 21st May 2019
xElvis's Avatar
Ok. So I swapped out the Accessory fuze. Partly better. I'm still partly stymied. Tail light is on, but no brake. I have a guess on that one, from previous wiring work.
Horn now works.
However, front amber on left side is off, until I hit the signal, THEN it lights up and blinks. Cancel signal, amber is dark. The right side one works fine.
Old 21st May 2019
Now that you have a working/powered ACCY circuit, double-check the Taillight circuit board...
Here's the Sportsterpedia section on Turn Signals with a diagram of the TailLight circuit board(see 2004-2006):
Check power coming into the board at Pin#1 - Then check to be sure the bulb itself is not burned out...
Both of the front TS/Running lights use the #1157 dual-filament bulbs as does the rear Tail & Brake Light...
Make sure all these bulbs are good (both filaments) - if bad, swap one from another location into that socket to confirm the wiring is in fact working...
Old 21st May 2019
xElvis's Avatar
I thought for a brief moment of the dual filament, and thought that the front ambers were not. Again, bad head for electrics. 1 bulb should sort that and pretty sure I have one laying around. I think some previous wiring work / project will sort the tail. Get back once I get to that.
Side note ... I was baffled for a second as I tested my signals today after swapping fuzes. The front and back signals were swapped on sides. I likely screwed up which housing was which while adding the current bars some months back. Oops. Amusing now though, to see the front left and rear right both turn on with the right switch.
Again, the help is appreciated.
