0 Rear Rocker Gasket Blown
0 93 Sporty Key replacement
0 Mid West Meet & Greet
Last Post: Bow only
0 4 Speed Stator Replace
Last Post: connorneil13
0 Pics of your significant other
Last Post: rocketnorton
0 Huge pile of Ironhead Parts
5 1969 XLCH exhaust question
0 Should I buy a Sportster??
Last Post: Medyo Bastos
0 Generator removal
0 Lifters Comparison
0 Simplified Wiring and Bars
0 compression low?
0 Spark plug discrepancy
Last Post: Ted Town
0 I'm back...
Last Post: Reverend G
0 1967 Harley Sprint SS250
Last Post: Crash7557
0 mixing brake parts
Last Post: Clevspeed
0 Mid or forward controls.
0 ultima electronic ignition
Last Post: rich56
  #51
Old 18th June 2019
EL in NH's Avatar
EL in NH EL in NH is offline
Sportster/Buell Model: model 48
Other Motorcycle Model: FLHS
Other Motorcycle Year: 1991
EL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to behold
Guess that means we're both deaf 'cause the internet says they clatter, or clattered...
What exhaust and tuner are you running? Your AFR walks around quite a bit and goes very lean at high rpms.
SUPERTRAP 2-1 and TTS... the tune/AFR is a mess I know..Got to get to the tuner...riding around with a laptop strapped to my back is crazy.
Peace
Old 18th June 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
You're now our internet expert? I don't see you posting any actual results for your "better" choice.
You've seen the dyno comparisons. Want me to repost them for you? Honestly I can't believe you went with those cams despite those.
My choice aside, there's more choices available that would've been far better and you know it.
My dyno isnt far out. Have an exhaust leak issue to fix and im tuning my carb with an AFR gauge then schedule in Madison, WI and we can put this to rest.
Where is your dyno results? You could meet me in Madison and compare my carbed version to your EFI.
For the money he spent on head work and cams, his dyno results are sure nothing to brag about, huh?
Old 18th June 2019
EL in NH's Avatar
You really expect anyone to take you serious. A stage one with an illegal ,(in NH) piss off the neighbors, pull me over exhaust is all we need to make close to 90 hp..yeah sure.. ..done and out...
Old 18th June 2019
60Gunner's Avatar
Chief of Security
Hey genius read my recent posts. I'm running the Khromewerks HP Plus slip ons.
All that money wasted. I'd be pissed too.
Old 18th June 2019
I couldn't have said it better.
Old 18th June 2019
60Gunner's Avatar
Chief of Security
Yeah, I didn't think you'd show up to get beat by a carbed motor. I'm done here.
At least now you have an answer to your question. Look at his results for your answer.
Old 18th June 2019
... I'm done here...
Bye...
Hopefully Aaron will get a chance to test the .551's and .585's in an EFI 1200.
Old 21st June 2019
Huginn's Avatar
Huginn Huginn is offline
Sportster/Buell Model: XL883N Converted to 1200
Sportster/Buell Year: 2016
Huginn has a spectacular aura aboutHuginn has a spectacular aura aboutHuginn has a spectacular aura aboutHuginn has a spectacular aura aboutHuginn has a spectacular aura aboutHuginn has a spectacular aura aboutHuginn has a spectacular aura aboutHuginn has a spectacular aura aboutHuginn has a spectacular aura about
Got pulled away for an emergency response project. Damn work is really getting in the way of my hobbies. Hopefully get time this weekend to finish the XL.
Old 4th July 2019
Just a follow-up.
I like these cams. They're not real happy under 2,000 rpm but (after much playing with PV mapping) they will run along at 1500 rpm in 5th gear (without doing the stagger / lurchy) puttsing around. They do run nice above 2,000 rpm and feel like they have a nice rising torque curve to 4500+.
I'm a bit old school and 4,000 ft/min mean piston speed falls at 6,300 rpm, 4,500 ft/min at 7,100 rpm so I really wanted to stay at 6,500 rpm max shift points (6,700 rpm limiter) and the cams pull hard to there. I find I'm shifting at where "that's enough". It hits the 6,700 rpm limit hard.
I'm hoping Aaron will do a test with the .551's and .585's in an EFI 1200 with an exhaust other than the (3+ yrs? out of production) Defender...
Old 5th July 2019
I personally would never run any of my Sportiest at 1500r.p.m. In fifth gear. I try keeping them in the 2800-3500 range.
