0 Your Favorite Style
Last Post: D-RAIL
0 T bars or Apehangers???
Last Post: D-RAIL
0 Michigan Thumb Run:
0 Ok 1200 to 1275 for street performance
0 Opinions on colour
0 Mid West Meet & Greet
Last Post: SteveK
0 Chinee Ignition
Last Post: c1skout
0 Stock (?) 1974 cobra style seat won't fit.
Last Post: Parker 1000
Last Post: hexnut
0 Turbo Iron 883
Last Post: Cj_
Last Post: Freqman1
0 No oil flow
0 Rear Crash Guard/Bag Guard Needed
Last Post: Joe_jeep
0 Bad Gas
0 Proper XLCH
Last Post: XL100
0 How packed is your garage?
0 Hello from Canada!
Last Post: robbie202
0 Model year seat differences / interchangeability issues?
Last Post: ivanford
Last Post: SLW210
alrbarton (75), fatelvis, welshturk, 6469 (51), udder (48), bullittmcqueen (39), bgp1 (38)
Old 27th May 2019
1mellom8 1mellom8 is offline
Sportster/Buell Model: XL1200 S
1mellom8 is an unknown quantity at this point
Cool 1997 Sportster S putting +4 front forks?
any advice? any good kits? I think the S has a little different forks than regular sportys?
new to this bike!
Old 3rd June 2019
Diogenes415's Avatar
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XL883C
Franks Forks (AKA 'Forking by Frank' back in the old days) has been in the biz for a long time... that goes a long way. TC Bros sells 'Moto Iron' forks which seem to be decent. I went 6 over on my '98 and love the added clearance and the ride. Although I can feel the difference at low speeds it's not as crazy as people make it out to be. I can predictably control the bike with one hand (I made my bars only 22" wide) and with any speed over ~20 mph I can't even tell the forks are longer. The bike tracks straight and true with 'no hands'.
Nope, it's a Sportster.
Old 4th June 2019
LocoLocal's Avatar
LocoLocal LocoLocal is offline
LocoLocal is an unknown quantity at this point
Following as I would like to do the same with my S. Would love to keep the dual disc front brakes though. I'll report back if I find anything!
Old 4th June 2019
LocoLocal's Avatar
Well, shucks, there is this...
http://www.chopcult.com/forum/showthread.php?t=46755
Old 6th June 2019
@locolocal thanks mate! that’s some great info. i’m looking into just swapping my front end with someone from a regular sporty. i don’t really care about the dual front brakes all that much
Old 7th June 2019
LocoLocal's Avatar
Good luck with the swap! Keep us updated.
I don't care much about keeping the adjustable suspension but would like to keep the dual front brakes. I think I will have to look for another model's front end if I want to stretch it a bit under those circumstances.
Old 18th June 2019
rezchug's Avatar
rezchug rezchug is offline
Sportster/Buell Model: 1200
rezchug is an unknown quantity at this point
It's okay +4 just looks like a welfare wannabe chopper.
Had +4 a few yrs ago but switched to a -2 wideglide fork.
It doesn't handle very good especially at highway speeds on corners but at slow speed its similar to stock.
If you try to go over +4 it looks very sad, almost pitiful especially when the guy is riding by a real chopper, it screams poor wannabe
Old 19th June 2019
Hey! you CAN get a larger tool bag under your bottom triple tree.
Old 22nd June 2019
super duper +1 on handling change
you will notice slow speed turns will have a higher stall speed unless you rake it to bring geometry back inline.
you will find a harsher ride on crappy surface since the angle of the dangle is changed
i doubt 4" will do it but there is the issue of pogo or harmonics at a certain speed.
this was a common mod back in the 60>70's and is an "OK" look. chopper is in the eye of the beholder, look at vintage hell's angles pic's and footage, even they accepted the look.
btw: been there, done that
Old 22nd June 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Adding any more than 4" without raking it is what looks like a welfare chopper. +2 or +4 tops is acceptable.
I gained a little just putting the Intiminators in and running the same amount of oil. Dropped the rear 3/4" and stability is way better and gave it the look I was after. No more brake dive either.
