Last Post: ronccc
0 Your Favorite Style
Last Post: D-RAIL
0 T bars or Apehangers???
Last Post: D-RAIL
0 Michigan Thumb Run:
0 Ok 1200 to 1275 for street performance
0 Opinions on colour
0 Mid West Meet & Greet
Last Post: SteveK
0 Chinee Ignition
Last Post: c1skout
0 Stock (?) 1974 cobra style seat won't fit.
Last Post: Parker 1000
Last Post: hexnut
0 Turbo Iron 883
Last Post: Cj_
Last Post: Freqman1
0 No oil flow
0 Rear Crash Guard/Bag Guard Needed
Last Post: Joe_jeep
0 Bad Gas
0 Proper XLCH
Last Post: XL100
0 How packed is your garage?
0 Hello from Canada!
Last Post: robbie202
0 Model year seat differences / interchangeability issues?
Last Post: ivanford
alrbarton (75), fatelvis, welshturk, 6469 (51), udder (48), bullittmcqueen (39), bgp1 (38)
Old 26th May 2019
201648Rider 201648Rider is offline
Sportster/Buell Model: 48
Sportster/Buell Year: 2016
201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future
Default Lifted 48
https://photos.app.goo.gl/i9LhLMpkyvNgmeiw8
Lifted 48 today via roadsters shocks. My spine approves.
Old 26th May 2019
Those 48’s look even better lifted.
Old 27th May 2019
wedge's Avatar
wedge wedge is offline
Did you lift the front too? If not, make sure it's stable at high speed if you run freeways.
The LA area is all freeways, so I like to lower the rear and raise the front for added rake.
Just a thought.
Old 30th May 2019
I swapped to progressives in the front but I don't think they raised it much. I think 48s are squatty in the rear from the factory. It feels really level now if not still a little lower in rear but that might be an illusion with higher bars.
It made a huge handling difference, and for the better. Most noticibly on rough roads and in the turns. I no longer feel like I'm grinding my heels when I lean in. Does wonders stretching out my legs at stoplights too.
I primarily ride freeways (central FL) here and I think it feels more stable which is weird, perhaps its because it raised the center of mass and makes it harder to lean in, wheras before it felt more eager to teeter/twitch? I also swapped for fresh tires and part of that could be getting rid of the old squared off rear .
Definitely needs a longer kickstand now, logic says with roadster shocks I should be able to use a roadster kickstand if I can find one.
I regret not doing this a couple years ago.
Old 20th June 2019
EL in NH's Avatar
EL in NH EL in NH is offline
Sportster/Buell Model: model 48
Other Motorcycle Model: FLHS
Other Motorcycle Year: 1991
EL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to beholdEL in NH is a splendid one to behold
I lifted my 48 at the rear with Ricor shocks. Smoothed out the front suspension with an Ohlins cartridge kit ..
Peace
Old 20th June 2019
wedge's Avatar
+1 on the squared off rear. New tires always make the bike feel smooth as silk in corners.
Old 5th July 2019
@EL in NH Thats a great looking 48!. Hows the lean on the kickstand?
Mine was leaning severely after the lift but I picked up a 2016+ roadster kickstand and it worked perfectly.
Old 14th July 2019
EL in NH's Avatar
Yes..terrible lean..I did what you did..I forget what model it came from though..it's been a while. Major bummer is I had to get rid of that beautiful exhaust as I could not get an inspection sticker. And I did get pulled over for not having one. They are cracking down on louder exhausts in NH. If you are just passing thru it would probably be fine . Along the sea coast the towns have been making a stink about the noise of the tourist bikers heading for Maine etc.
