0 Oil amount
0 900cc Pistons
Last Post: Staffords
Last Post: Turbo Sporty 48
2 Your daily tunes...
Last Post: RDHenley
Last Post: ivanford
0 88ci Sport Rod
Last Post: CaptainZoop
0 Help!!!
Last Post: rocketnorton
0 Stock pipes
Last Post: DéDé
Last Post: Oldmxdog61u
0 Proper XLCH
2 Humble pie
0 A Day in the Life...
3 2005 XL883 Standard for sale
Last Post: SLW210
0 The last of a dying breed...
0 '81 Gasket/Rebuild Questions
Last Post: Andy Hog
dave (71), Miami (70), MnKevin (65), bigdogbark (64), robby269 (60), larry p (58), MadDogXR, kev883 (56), 0ut1aw (56), Nu Viking (54), dlclark804 (51)
ignition, screaming eagle
Old 25th May 2008
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
Originally Posted by Turbota View Post
Well, due to final drive gearing differences between the 04-05 bikes and the 06 bikes, I can't see how the speedo would ever be accurate if used on an 06:
04-05 XL1200 VSS freq is: 1386
06 XL1200 VSS freq is: 1624
That's an 04 P/N. The speedo will be accurate on either the 04 or 05 1200 bikes, but I can assure you that if used on an 06, the speedo will be WAY OFF!
What is the gearing difference? I thought the '06s had:
US: 38/57, 29/68
HDI: 38/57, 30/68
the same as '04 - '05?
Folkie
South East England Riders
Old 26th May 2008
Lurch77's Avatar
Lurch77 Lurch77 is offline
Other Motorcycle Model: Suzuki GSX-R750
Other Motorcycle Year: 1993
Lurch77 is on a distinguished roadLurch77 is on a distinguished roadLurch77 is on a distinguished roadLurch77 is on a distinguished roadLurch77 is on a distinguished road
Thanks for the replies everyone. If anyone with a 2004-05 is interested, I listed it in the classifieds. Just looking to unload it for what I paid. http://xlforum.net/pp_classified/sho...1&cat=4&page=1
Old 26th May 2008
Turbota's Avatar
Turbota Turbota is offline
Lurch ... Since you already have that 04 module, how about just sticking it on your 06 and reporting back here how it worked ... nothing gained, nothing lost
It's a 2 minute job ... you may or may not have to do the "ICM Initializing procedure", but that's easy.
04 XL 1222R
Old 12th June 2008
jalopy jalopy is offline
jalopy is an unknown quantity at this point
I have an 06 and just put one of these on my bike. To say that the speedometer is WAY OFF is an understatement. It acts like a tach under heavy acceleration through the gears. up, down, up, down. Hit the throttle from a steady speed and it starts jumping up faster than it should.
Does anyone know why it throws the speedometer off so much on the 06 models?
Old 18th April 2009
jsmckinn jsmckinn is offline
jsmckinn is an unknown quantity at this point
I installed p/n 31785-04A on my 2006L a couple of weeks ago. Great performance, but the speedo is WAY off. This is frustrating. Awesome performance, but cannot stand the inaccuracy. It took me a half-hour to password learn it to the bike, just to have this happen.
Old 23rd April 2009
I found the correct ignition box, which happens to be discontinued by Harley. This ignition box is specifically for the '06, and the p/n is 32471-06. This is a plug and play box, with NO password learn procedure required. It took me less than 5 minutes to make the swap, fire the bike up, and ride away. No more detonation, speedometer reads correctly. If you do a Google search with just the part number, there will be a few dealerships from around the country who still have this ignition in stock. It is $119.95+ shipping/handling. Very happy with the results.
Old 7th May 2009
sawtooth's Avatar
sawtooth sawtooth is offline
Other Motorcycle Model: Triumph Bonneville
Other Motorcycle Year: 1979
sawtooth is an unknown quantity at this point
Great...so I am screwed too. I picked up a 31785-04 over the winter for my 2006 1200C and tried to install it last night..and of course it went into password mode and wouldnt start.
Having read this thread, it appears that it won't work! Or if it does... I am going to have other issues. Big waste of time. Any ideas?
My season is short enough without wasting time playing with this thing.
I wonder if anyone else makes an high performance ignition box... other than HD?
Old 7th May 2009
Lenster's Avatar
Lenster Lenster is offline
Lenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond repute
Daytona Twin Tec TC88A.
Lenster's 1250 2006 XL1250C, Hammer Crush Heads, 15 Degree Pistons, 10.5:1 CR, S&S Roller Rockers, Fixed Length Pushrods, Jim's Powerglide II Hydraulic Lifters, RedShift 585 Cams, Energy 1 Clutch w/ 15% Stronger Spring, Hammer Performance Billet Intake Manifold, Mikuni HSR 45 (25 Pilot, 157.5 Main, 96 Needle 2nd Clip from top, Y6 Needle Jet), Offset Crush AC, Cobra Power Pro HP 2:1 Exhaust and a Daytona Twin Tec TC88A with a Kickass Map by Rico 05R.
Old 7th May 2009
sawtooth's Avatar
ouch $$$$$ (thank you for the information)
i wonder if a stock or se module could be reprogrammed?
if people can flash pc video cards..why couldnt they flash an HD ignition module?
Old 7th May 2009
FoxsterUK's Avatar
You know you have to run it through the learning procedure, right?
You should be able to get it to work, depends then whether you can live with the speedo reading a bit wrong. It wouldn't be hard to calibrate the speedo using a cheapo SatNav and mark up the glass.
Fox
