0 Oil amount
0 900cc Pistons
Last Post: Staffords
Last Post: Turbo Sporty 48
2 Your daily tunes...
Last Post: RDHenley
Last Post: ivanford
0 88ci Sport Rod
0 Help!!!
Last Post: rocketnorton
0 Stock pipes
Last Post: DéDé
0 Proper XLCH
2 Humble pie
0 A Day in the Life...
3 2005 XL883 Standard for sale
Last Post: SLW210
0 The last of a dying breed...
0 '81 Gasket/Rebuild Questions
Last Post: Andy Hog
dave (71), Miami (70), MnKevin (65), bigdogbark (64), robby269 (60), larry p (58), MadDogXR, kev883 (56), 0ut1aw (56), Nu Viking (54), dlclark804 (51)
Old 31st August 2009
scottsxl1200's Avatar
scottsxl1200 scottsxl1200 is offline
Other Motorcycle Model: Fatboy
scottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant future
Looks like it belongs there! Great job!
I didnt say it was your fault, I said I was going to blame you!
Old 1st September 2009
gmcretz's Avatar
gmcretz gmcretz is offline
Sportster/Buell Model: None yet
gmcretz is an unknown quantity at this point
TechRep, fantastic write up and great pics of the whole process. Ingenious way to mount the tank, to get it aligned properly, and the look is spot on!
Great Job!
"Give me an Army of West Point graduates and I will win the battle. Give me a handful of Texas Aggies and I will win the war!"
General George S. Patton, Jr.
Old 12th September 2009
merc merc is offline
Sportster/Buell Model: Custom
Other Motorcycle Model: Suzuki GN400
Other Motorcycle Year: 1980
merc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond repute
super write up. I love the look it provides.s.
I have to add it to my "must do's someday" list.
Old 2nd November 2009
Patmicg Patmicg is offline
Patmicg is an unknown quantity at this point
REviving this thread as its awesome and im sure tons of people want to do this,
but what do you guys thing the odds of being able to pull this off on a EFI sporty would be. I cant find any pictures of the bottom of a dyna tank to see if the efi systems match up. Then again im not really that sure what to look for
Erik's Avatar
Erik Erik is offline
Sportster/Buell Model: SOLD 883/1200 Sportster
Sportster/Buell Model #2: -
Sportster/Buell Year #2: -
Other Motorcycle Model: KTM 990 SMT
Other Motorcycle Year: 2009
Erik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to beholdErik is a splendid one to behold
Originally Posted by Erik View Post
This is triple-A write-up stuff.
Lots of talented people here, and you're certainly one of them. Have some well deserved rep.
Edit : Have spread a bit to much rep around the last 24 hours, I'll get back on that
...I finally got back to you for the promised rep ! well deserved
Erik
(A Dutch Rider)
Old 3rd November 2009
TechRep's Avatar
TechRep TechRep is offline
TechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of lightTechRep is a glorious beacon of light
The bottom of the tank is pretty straight forward with a bung and crossover tube.
Because the fuel injected tank has the attachments inside for the pump etc, my guess would be that if you used the Dyna tank with the Dyna pump/parts, it should be no problem. Your original harness already has the pump wiring.
The tank I used for this conversion was a fuel injected tank. I just did not use the fuel pump because my bike is a carb motor and I only needed to wire the gauge.
It would be interesting to compare a Dyna EFI tank parts list with a Sportster EFI tank parts list. My guess would be that the pump itself, minus the mounting and tubing would be the same number.
TechRep's Avatar
Thanks Erik!
Old 17th November 2009
OK so i did all the research to see if this was possible and heres my findings,
The main problem that we would be running into doing this is that the efi on the dnas bolt in from the top. So we would have to either figure out how to get the sporty one in there but its made to come from the bottom, or rewire the dyna one. There hasnt been much said on the volume thats going through the unit. The next problem is the fuel line connector to the tank. The sporty uses teh funny airhose like connecter while the dyna doesnt and it doesnt seam like theres a way to get it to fut unless you cut out a sporty connector and out it on a dyna tank via welding or you splice the line on the sporty engine somewhere between the throttle body and the tank.
SO! it can be done:
Dyna tank ~200
dyna efi~ 250
custom work to either cut and splice lines or weld on sporty connector~???
fabbing up brackets to fit dyna tank~ 5
center console~??
So hopefully someone will read this and turn it into a winter project
Old 22nd December 2009
jordan1200's Avatar
jordan1200 jordan1200 is offline
Sportster/Buell Model: 883/1200 Hugger Sportser
jordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant futurejordan1200 has a brilliant future
Did anyone ever say if this or another tank like it would work on a pr-03?
Jordan1200
1999 883 Hugger/1200 TS conversion,Buell domed pistons
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
Dynatek DC6-5 Single Fire Coul
SE 1340 air cleaner
Bassani Road Rage 2 into 1 Long Exhaust
Old 6th January 2010
dholt's Avatar
dholt dholt is offline
Sportster/Buell Model: XL 1200L
dholt is an unknown quantity at this point
I love the beefy look of this conversion. I have the XL 1200 L and would love this look. My bike is an 09 and I keep running in to the EFI issue. Would this conversion work on the 09. This is my first bike and I have no mechanical skills or knowledge whatsoever. On a side note, you did such a great job, have you thought about putting a kit together and selling it complete with brackets to someone like me with no access to the tools to do create them? If your interested, send me a private message.
Darren (Back in Black in SLC)
'09 Black XL 1200L Plenty of Show, Time for the Blow!
The Edge...there is no honest way to explain it because the only people who really know where it is are the ones who have gone over. (Hunter S. Thompson)
