Last Post: Sportster25
0 Today's rant
0 New to an XL
0 Rear Motor Mount Blind Hole?
Last Post: joe s
Last Post: Racepres
Last Post: wolfryder
0 Helmets Please...
Last Post: gusm2
0 Helmet music questions
0 Wow! Very impressed with DK Custom Products' Headlight Relocation Kit for Iron 883
Last Post: focodave
0 Frame mount vs Rubber mount engines
0 Harley Hacks & Tech Tips - Build It Better™ - So Much Useful Info!
0 Help insanely loud decel pop after 1250 kit
0 Custom painted Forty-Eight tank
0 New from the cold north...
Last Post: hoggy
0 New to here
0 First post, 01 1200C controls question
Last Post: wiltybob
0 oil tank
Last Post: Captain Johnny
0 mikuni vm38/9 on a 2001 xlh
0 Tool/trick for headlamp nut removal?
Last Post: Racepres
0 Francis
0 Muffler adventure and Uh-oh
Last Post: Mike1nw
jlede (73), hissatsu (68), Mickey Shane (68), jiffylube (57), TEAMGREEN (52), pirogue1 (48), soupman77 (47), kromroykw (46), O48 (46), dracolich, STEVOMERCKX (38)
Old 18th March 2023
Dr_ransom Dr_ransom is offline
Sportster/Buell Model: XL 1000
Sportster/Buell Year: 1979
Sportster/Buell Year #2: 1959
Other Motorcycle Model: XLX 1984
Dr_ransom is an unknown quantity at this point
Default Belt drive for E84 XLX
Greetings:
I am going to convert my early (has generator) 84 xlx to a rear belt drive.
I know I'll need to special order a front pulley (from supermax or hillside), unless someone here
has one they want to sell, and I'll use a rear pulley 40258-89.
Also, I will use a 128 tooth, by 1 1/8” wide belt.
From what I read, I should use a front pulley with 27 teeth & a rear pulley
with 61 teeth. (This is from the 1986 XL chain to belt conversion kit info, 40110-89)
My questions are:
1. Will the rear pulley 40258-89 fit on the wheel (stock wheel)?
2. Given the 27 teeth front pulley & 61 tooth rear pulley, will the 128 tooth
belt be the right size?
3. Do I need to modify the swing-arm?
Thanx in advance
DR
Old 19th March 2023
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Gonna be a bit hard to answer.
Not a bunch of XLX owners here. Me being one. Mines a year newer. Alternator version.
I have no future plans of converting mine to belt.
Maybe look through search box below this thread. Then Sportspedia. I can't think of what else to contribute but buy the parts and make them fit since a one off. Wheels are pretty standard but not sure really when it comes to XLX, swingarms, wheels, position and spacers.
Traveled to
Old 19th March 2023
PoodlePunche's Avatar
PoodlePunche PoodlePunche is offline
PoodlePunche has a brilliant futurePoodlePunche has a brilliant futurePoodlePunche has a brilliant futurePoodlePunche has a brilliant futurePoodlePunche has a brilliant futurePoodlePunche has a brilliant futurePoodlePunche has a brilliant futurePoodlePunche has a brilliant futurePoodlePunche has a brilliant futurePoodlePunche has a brilliant futurePoodlePunche has a brilliant future
For my own morbid curiosity... why do you want to go to a belt?
Most people want to swap from belt to chain...
DC2 SW/AW
Chrome is a terrible scourge on humanity
YouTube
Old 19th March 2023
Default reply1
Hi
I have a 82 Sturges, and its belt drive, and after owning it for 1.5 years,
I like not having the oily mess and the added maintenance.
Also, my friend is a old time bike builder & he will help me out, and
money is not a problem.
And add to that; I'm little crazy anyway...
I've been looking, and it has been done before.
Thanks for your reply
DR
Old 19th March 2023
1Scooter 1Scooter is offline
1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of
Ya gotta consider, the Ironhead Sportsters were designed for chain drive. 530 chain is 3/4" wide and rides over the sprocket, giving it a very tight fit with a tire. Belt on a pulley is 1 1/2" wide. A belt pulley is not going to fit under the sprocket cover, AND you have concerns about modifing the swingarm. Better think this through before ya waste money on a pipe dream.
Old 19th March 2023
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant futureericfreeman has a brilliant future
I use a high quality X-ring chain and Amsoil Metal Protectant as a lube. It dries so there's no mess to deal with. I figure the once a year cleaning I give the chain it's well worth it for the strength.
Eric
Old 19th March 2023
Eric
indeed...
I've ridden chain bikes for over 30 years, and have never had a mess, and the only failure was due to contact between my dirtbike and a stump...
clean/lube it once (maybe twice) a year, and make sure to wipe off the excess afterward...
If it's making a mess, you've got too much lube, and it's probably too loose.
