Stairman, toby61, Greywolf (73), federico (70), Big D (69), robin82732 (58), jbd777 (52), Steve3888 (50), RIORoosen (48), NXC1978 (44), JeffsJeep04 (37), Matt.loup.t |
15th May 2022
Posts: 18 Sportster/Buell Model: 1200XLS Sportster/Buell Year: 1996 Other Motorcycle Model: 2005 FLHRCI
ELectrical Issue 96 xl1200s
Key on....hit start and headlight dims and no start.
Turn key switch on and headlight is dim sometimes and bright at times until you push start then dims and no start.
Battery checks out good. Just wondering what else to look for?
Thanks for any help.
16th May 2022
Posts: 400 Sportster/Buell Model: XLH1000 Sportster/Buell Year: 1977 Sportster/Buell Model #2: 2004 XLH1200Custom Other Motorcycle Model: 2007 FXDB Other Motorcycle Year: 2004
You need to isolate the problem. Starter switch? Wiring issue? Starter issue? Solenoid issue? OK, now ya got something to try. Turn ignition on. DO NOT PRESS STARTER BUTTON. Jump the solenoid to battery. If it starts, it's a switch/wiring issue.
16th May 2022
Posts: 9,353 Sportster/Buell Model: Sportster 883►1200 Sportster/Buell Year: 1994
When you're having issues with the electrical system, use this Sportsterpedia section
about checking the battery cables, voltages and grounds - DO THIS AS MAINTENACE, TOO:
How did you test the battery? Do the 4 voltage checks as listed in the link above. Report your meter readings.
Be sure the ground wires are not broken or corroded at the rear motor mount.
Have you done any work lately on the handlebar switches? Check for pinched wires. They may be grounding.
Do you have extra stuff on your keyring beside the Sportster key? Other things blowing in the wind can sometimes create stress on the keyswitch & eventually break the internal contacts (causing intermittent operation or shorts).
For Sportster Tech Info:
17th May 2022
Posts: 11,038 Sportster/Buell Model: 1200s Sportster/Buell Year: 2001 Sportster/Buell Model #2: xlch Sportster/Buell Year #2: 1974
had issues with my 01 sport
was the connectors inside the headlight bucket, also check for burned socket on bulb, replaced mine with ceramic.
