Last Post: Dave L
0 How old are you?
Last Post: RandyMac
0 Does anybody know the difference between these two kits?
Last Post: Sadsack
0 Carb, manifold issues
Last Post: SteveK
6 1973 Sporty - Starts, Runs Good, Stops...
Last Post: brianbbs67
0 Lake Erie Ride Alums?
Last Post: SteveK
0 1991 883 Hugger will not turn over
Last Post: Four Speed
Last Post: Diogenes415
0 Passenger floorboards and backrest questions
Last Post: chris16371
0 S&S Super B float needle question.
Last Post: Captain Johnny
0 Analog Tach on 2004-2013 Sportster with OEM Digital Speedometer
Last Post: stray
0 Issue that has me stumped
9 MAP code problems
0 Which cam?/ 551 or 570/Why?
Last Post: jcro61
0 Any here have experience with B cell Luekemia?
3 Ironhead Pictures Thread
Last Post: DirtyHarry68
0 ‘68 XLCH...transmission
0 1993 sportster / loud grind no go
Last Post: Nightrain
0 Question about dynamic timing a 2000i
Last Post: jordan1200
0 THE Trainspotting Thread
0 Cafe' Image thread WTFN
Last Post: tigger
Last Post: Blowupster
0 Puked oil or primary fluid
Last Post: painterdude923
Last Post: lugster
sounds like yours don't need rebuilt but a leaky weld gone over? they should be disassembled first,but this wouldn't even require new parts?
Chuckthebeatertruck's Avatar
Chuckthebeatertruck Chuckthebeatertruck is offline
Senior Master Bike Builder
Sportster/Buell Model: Xlh
Sportster/Buell Year: 1959
Sportster/Buell Year #2: 1969
Other Motorcycle Year: 1969
Originally Posted by Whitewalls View Post
I thought I was on track to get a new set from Hagon. They emailed yesterday saying they cannot make shocks for my '71CH because of the 5/8 holes.
Slow your roll, my friend.
Unless I'm missing something, Hagon uses regular old rubber shock bushings in the eye.
I'd have to see them in hand; but the most common construction is either a metal or composite "sleeve" inside the rubber bush so the shock stud doesn't wear the rubber out (quickly).
The trick is to press the rubber bushing out of the shock eye. Most of the time, the sleeve will separate from the bushing when each component is brand new. It's usually a bit of a fight, but if you make up a press tool -- they come out with a wee bit of tearing to the bore. This is ok because our next step is to use a sharp drill bit to enlarge the hole, and press in a new 5/8 sleeve.
However, some newer bushes are molded around the sleeve -- and so you have to be more creative.
The trick there is to press the rubber bush out of the shock eye, then chuck them in the lathe and skim them out from 1/2 or 13mm to the 5/8 you need. You can also do this with a good vice and a drill press -- just make sure your drill bit is VERY sharp as we are cutting the sleeve out bit by bit. I'm not blowing smoke here -- I most recently did this to run a set of shocks I liked on my 79 Guzzi. The bushes were 2mm too small . . . .
If you really want it done, you can also buy rubber or urethane and make your own bushes. I've done it a few times out of oversized bottle stoppers from the chemist. I've also done it out of left over delrin. I honestly never noticed a difference between rubber and delrin bushes other than the delrin would "squeak" when cold.
You can also just type in "shock bushing" and you'll be surprised what comes up.
https://www.jegs.com/i/QA1/122/B6031...iABEgItKPD_BwE
This is one of those times where you may need to be a bit creative and out of the box to get what you want off the shelf.
You can also just make new shock studs in 1/2" . . . if you have a lathe and a little patience. I've done that on a few bikes -- most recently my duoglide frame so I could run Showa airshocks.
Don't let something as silly as the bushing size slow you down.
Whitewalls's Avatar
Sportster/Buell Year: 1971
Other Motorcycle Model: 1966 Honda Dream 160
Whitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant future
Not that simple. The struts are oil filled and nitrogen charged.
rg500 rg500 is offline
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1971
rg500 is a jewel in the roughrg500 is a jewel in the roughrg500 is a jewel in the roughrg500 is a jewel in the roughrg500 is a jewel in the roughrg500 is a jewel in the roughrg500 is a jewel in the roughrg500 is a jewel in the roughrg500 is a jewel in the roughrg500 is a jewel in the roughrg500 is a jewel in the rough
The "K-Tech Razor III Lite shocks" have 1/2" holes like late 75-78 XL, when I rebuild older XL's I always change to the late shock studs,
I try to find Showa shocks late 75-78 XL on swap meets, they are often really fine and people have replaced them to lower shocks or hard tail so they cost almost nothing.
XLCH 1971 with "Showa"
XLH 1978 with a better image with "K-Tech Razor III Lite shocks"
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
I have done exactly what you describe. Sometimes it easier to swap the bushings with insert out completely. If your old ones are good. As Chuck says, it not that hard of a mod.
Ok, now I'm revived
