Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Transmission, Clutch, Primary & Secondary Drive
0 Rain pants
0 Rear Sprocket for Belt
0 Issues with my jiffy stand... HELP!
Last Post: corndog76
0 Any1 running this ignition??
Last Post: TwistyMcFisty
0 Celebrating Sportsterpedia's Fourth Anniversary
0 Changing stock Speedometer mount
Last Post: sarcvicious
Last Post: spoon
0 Sleeve cylinders?
0 Early 60's headlight "brow", "mount", "visor" or whatever you want to call it.
0 Too HOT to ride?
Last Post: spamer80
3 Shaky Dave Recovery
Last Post: ezmerf
0 Which Battery?
0 Hi from Spain!
Last Post: Magneto Sportster
0 Getting Hammered
Last Post: Bryan83taco
nvlarry (65), Harby (65), gregor (62), Rainman (62), Dubfire (59), flathead45 (55), Shu (49), matt1971 (49), dgarber12771 (49), grino1200C (41), adamsmd127 (40), ws6envy (36), doomedcobra
Old 19th November 2018
Javelina1 Javelina1 is offline
Sportster/Buell Model: M2 Cyclone
Javelina1 is an unknown quantity at this point
Thumbs up Clutch hub bearing number?
Greetings from a noob to this forum. Name's Lou, I've got a '00 Buell M2 with 85k on it, all stock for the most part. I ride to work every day and play in the curves on the weekend when I get the chance. I'm also a machinist, make all my own special tools and have a complete shop at my disposal. I've been riding 41 years, on and off road.
The bike's been making a "clack" noise from the engine lately. The noise is synched to engine rpm, not road speed, as it makes the noise at idle and the frequency of occurrence goes up as engine speed does. Coasting, in neutral, engine not running, no noise. That pretty much isolates it to the primary. Noise is intermittent but regular as in "clack", "clack"........"clack".
I pulled the primary apart yesterday and all the bearings that are visible look fine, sprockets and primary chain are still low wear, new style primary tensioner (the one with the thicker steel plate) is good, and all the magnets in the crank sprocket are solidly in place and no other items seem odd. I did notice that the ring gear has been rubbing slightly on the vertical arm of the shift shaft, where it moves the shift drum. The clutch outer basket seems more wobbly on the inner than it should, so my wild a** guess is that the bearing has gone, not enough to ditch the ball separator and shed balls, but worn out anyway.
So, my question to all who read this is, does anyone know what the number of the bearing is? Not the Harley part number, rather the "trade number" of the bearing. (as a for instance, trade number 6202 refers to a bearing for a 15mm shaft, 35mm o.d. and 11mm wide.) If I know the trade number I can get one from the bearing house ahead of time and have it ready to install next weekend, rather than wait around for the Harley dealer to open, get confused, tell me they can order it and make me make more trips than Timothy Leary.
If you know the trade number, or even the I.D., O.D., and width of the bearing and can let me know, I'll be forever grateful.
Speed Safely
Javelina1
harley506d's Avatar
harley506d harley506d is online now
Sportster/Buell Model: 1200c
Welcome from France!
Hang around, someone will be on later to help.
A cross reference to all Harley bearings would be real useful. Save us all a fortune!
rocketmangb's Avatar
6202 would be a 10 MM shaft I believe
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Presuming that bearing is the same in the Buell as in the Sportsters...
According to Ronnies, the HD P/N for the Clutch Hub Bearing (91-later) is 36799-91 (Item #14)...
http://partsfinder.onlinemicrofiche....TCH%20ASSEMBLY
See this thread:
http://xlforum.net/forums/showthread.php?t=1675527
According to the image in these links, the bearing is a 6207:
https://www.ebay.com/itm/192052473245
https://www.dragspecialties.com/prod...umber=11320917
IXL _______ >>>> My Motorcyle Chronicles Are Here<<<<
Check Out The Sportsterpedia
There is one for Ironhead bearings:
http://xlforum.net/forums/showthread.php?t=548657
shanneba shanneba is offline
Welcome to the forums from Indiana!
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
IXL2Relax, that's what I'm talking about. 6207 sounds a likely suspect, and the bearing house has them for $13 and change.
Thanks to all who responded with useful info, and everyone have a good Thanksgiving holiday.
Speed Safely,
Lou (aka Javelina1)
the old BCA number might have been 207,more balls would be 1207
Old 25th January 2019
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
Bringing up the dead thread to give more info for people in the future, but if it is in fact the same bearing as the Sportster clutch hub bearing (I didn't look up the part number to verify) then you can use a 6207-C3 bearing. I've got that in my 2002 and it's been in there the last 40k miles without issue.
I used an FAG 6207-C3 you can get on amazon. It was the real bearing, but double check because sometimes the fakes come shipped to you.
https://smile.amazon.com/FAG-Clearan...ywords=6207-C3
http://i.imgur.com/Oe4Ttw0.pnghttps://i.imgur.com/AFv3AMo.jpg?1
