Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Styles > Dirt, Off-Road, and Adventure
0 question for our machinists
Last Post: Yakcm2
0 Fact or fiction?
0 Race tracks are harsh environments
0 You can't tour on that!!!
Last Post: RDHenley
Last Post: herostar
0 Black Friday/Cyber Monday Showoff Thread
Last Post: herostar
0 XLCH Plunger Seat Kit
Last Post: FatboyBill
0 hi all
Last Post: early iron
0 Swingarms
0 the roadster make more power ?
0 supply oil line seeping
0 Question on priming motor for kickstart
0 Interview of My Expieriences Riding in the Iron Butt Rally
0 Hydraulic Lift For XL
0 3.5" straight riser
0 Cometic Air Cleaner Gasket?
0 Fork Upgrade to 39mm. Is This Possible/Wise
0 Very Loud Backfiring (among other things)
Last Post: Nacs
  #41
Old 6th September 2019
shreksbro shreksbro is offline
Sportster/Buell Model: XL1200
shreksbro is an unknown quantity at this point
Originally Posted by 51 New West View Post
By the way - your project looks great. I'm not a fan of form over function, but your bike looks great AND looks capable.
The other thing I can personally vouch for is Pirelli MT60RS tyre for the rear and MT60 for the front. The rear is available in a reinforced variant which I used and I have to say they work well on and off road in dry conditions. I don't know how they would go for mud or wet pavement, but otherwise they are wearing very well and worked a treat. Of course, you may have other options available in the USA that I can't get here.
Thanks for the compliment. I'm pleased with how it's evolving, as well.
If I keep the factory wheels, the Pirelli tire you suggested is really the only option for the rear I've found, so it's good to know it's a decent tire. I'm thinking about sticking with the factory wheels just to stay tubeless... Changing a tube on the side of the road is an ordeal, whereas patching is a five minute job.
Sent from my SM-N960U using Tapatalk
The attached photo should explain it better. The tang on the frame that holds the jiffy/side stand spring snapped off when I rode off a low curb, so after I repaired it I fitted the square tube that is circled. I also made a cheap bash plate , but that tube does most of the work.
Now I understand, thanks. I didn't realize this was a weak spot on these bikes, but being under the frame it makes sense. I've got the factory skid plate from my GS I'm probably going to repurpose. Also Kuryakyn (or however it's spelled) now makes a skid plate for the Sporty that looks pretty cool.
Old 7th September 2019
Rode the bike to work today and it went along great. Only issue was the red security key came on. After a little Google-Fu, I concluded it was due to the LED turn signals I put on the bike.
I ordered a Badlands Illuminator from Amazon with free same day delivery and I've already installed it. It has the added bonus of making the turn signals brake/running lights, so that's nice.
The rear suspension is amazing. Better ride in bumps than any bike I've ever ridden... Very impressed with those Fox shocks.
I had picked up a KTM fender to put on the KTM front end I bought. Since that was a bust, I figured I would try the fender on the stock front end. I think it looks pretty cool!
I also bought some handguards and installed those. They'll just block some wind from the hands, they're definitely not the real deal like my GS, but they look pretty cool.
NLXL's Avatar
NLXL NLXL is offline
I like it, it's up for it's job I think! I think the front fender is a little short on the back of the wheel. Aren't you afraid that it will throw up mud, sand dirt or rain too much to your engine and in your face? Maybe a short one that only covers the back of the frontwheel and connects the two fork legs for stability?
The rear of the front fender interfered with that highway bar, which I definitely need due to my height. Also, I had concerns of it blocking the engine cooling.
My plan is to figure out a mesh to mount between the frame rails that will both block rocks and such as well as allow cooling air into the engine.
I'm certainly open to better suggestions!
NLXL's Avatar
I see. I meant a short piece of fender that covers the wheel, protects engine from dirt and does not block your cooling. I meant something like this:
https://www.yamahamotorsports.com/du...t/models/xt250
I suppose it's a bit like your GS, but without the front part.
dieselvette's Avatar
These are valid concerns, but I've had the front of my frame caked in mud to where the fender was hitting and squeezing it out. Doesn't seem to affect performance or rideability. Recommend cleaning it though once you're back on the beaten path, else it's hard to get off later.
Fender doesn't do anything for stability, but a Superbrace does.
I have a Cycle-Electric 38A charging system, so the voltage regulator doesn't fit between the frame rails, and the fender would hit just like with your highway bars. I re-drilled the mounting holes on the fender to drop it tighter to the tire (about 3/4" clearance now). Sometimes I hear rocks jamming through it, otherwise fine.
There used to be an Arlen Ness plastic fender available, ugly but could easy be modified to look good, and hug tighter too. And lighter.
____________________________________________
FIND HELP WITH YOUR SPORTSTER HERE: http://sportsterpedia.com/doku.php
If men can build it, men can fix it. - Tim Allen
2004 1200 Roadster Custom-Electra-Glide-Sport-Touring-Edition
SE air cleaner w/venting routed outside a/c
Supertrapp 2:1 pipe - usually 20 discs w/closed endcap
Stock CV carb w/ Yost tube + DS idle mixture screw
Cycle Electric 38A charging system
TC88A ignition
0.030 head gasket, zero deck-height
Hammer 570 cams
Bronze oil pump gear, updated oil pump
30-tooth HDI belt sprocket (137-tooth belt)
Old 8th September 2019
Gotcha. Good idea. Maybe I'll cut the factory one in half and paint it black so it's not noticeable.
Is this the fender you're talking about?
Fairly inexpensive for the brand...
https://www.easternperformance.com/a...xd-157089.html
Not exactly, but close enough. Straighten out some of the curvy lines with a saw or something, before painting, it would work great. I was going to buy one this year but blew the budget on engine work and other stuff.
