0 1968 ex barn dweller thread
Last Post: fafcpa
0 Flat Tracker Pics
Last Post: nutball73
0 82 XLH struggling for power
Last Post: Desertfox
Last Post: skien
0 Umbilical Hernia surgery report
0 my sunday driver...
0 -65A mufflers
0 carbs?
Last Post: jtoaster
Last Post: Robyart
0 Hydrostatic fuel gauge
0 Sifton cams on stock 74 XLCH
0 Chasing a generator noise
0 55* this morning
0 Better Brakes
0 Opinions on Mallory unilite ignition
Last Post: mikethebike61
Last Post: oldboy
0 S&s
0 Installing jugs finally but another Q
0 Li/Ion battery in '03
Last Post: Eric Von Zipper
0 Late-model stator on rigid-mount bike?
Last Post: Curbside
ebikerman (84), nalakk (79), blkjak (77), Dave.N (66), cousincletus (60), stretch7 (58), jockeyshift (56), juice900 (42), sportsterwheelies (40), live_loud (38)
Old 28th May 2008
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
Shu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant futureShu has a brilliant future
Default Blown a clutch? Please give details....
Lately it seems we are seeing a lot of post about clutch issues. A few short years ago you hardly ever heard anyone posting about their clutch slipping or complete failures. So what is causing the increase in clutch issues on our beloved Sportsters? Is it SportTrans fluid is no longer available and the new Formula+ or other alternatives people are now using is causing the clutches to slip? Was there a redesign? So I am going to ask a few questions to help us isolate if their could be a common cause. If you have ideas for additional questions to help isolate the cause, please PM them to me and I will had them to the list.
1. Year of bike
2. Model (1200/883/other)
3. Miles on clutches?
4. Fluid used when slipping of clutch began?
5. How many miles on that same fluid?
6. Did you perform routine adjustments per the service/owners manual?
7. Your riding style: Aggressive, semi-agressive, normal, and easy going
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
Old 8th June 2008
Phaedrus's Avatar
Phaedrus Phaedrus is offline
My clutch went this spring. It's at the indie right now.
I will add specific details with what went wrong when I see him on Monday.
Somthing broke and chewed up the clutch.
2006 1200C
25000kms
Syn from HD same as whats in the engine
3000kms on the fluid (was changed in the fall)
I adjusted the clutch last at about 15000kms
Riding style - semi agressive
Of course the warranty expired in April 08, started experiancing problems in May.
Rivets sheared off
Old 8th June 2008
Lynk's Avatar
Lynk Lynk is offline
Other Motorcycle Model: Yamaha YZF-R6
Lynk has a spectacular aura aboutLynk has a spectacular aura aboutLynk has a spectacular aura aboutLynk has a spectacular aura aboutLynk has a spectacular aura aboutLynk has a spectacular aura aboutLynk has a spectacular aura aboutLynk has a spectacular aura aboutLynk has a spectacular aura aboutLynk has a spectacular aura aboutLynk has a spectacular aura about
I'm installing an Energy One kit tonight, at 11678 miles on my 2006 XL1200C. I started using Amsoil MCV in the gearbox quite some time back. My style is aggressive, and the bike has seen a few nights at the drag strip. I adjusted the clutch per the service schedule, but noticed it starting to lose its grip last summer. Since then, I've put a max of a thousand miles on the bike.
Can't remember when I last replaced the primary case fluid, but I'd hope that I would have gotten to it at the 10,000 mile service. Fluid drained tonight was shimmering from metal dust, though otherwise appeared to be in good condition. Guess I may have caught this thing in the nick of time.
Michael
'06 Custom 1200
< SE .551 cams / SuperTrapp 2-1 SuperMeg exhaust / Forcewinder XR2 airbox / Mikuni HSR42 carburetor / TC88A ignition / Progressive 13" shocks>
Old 8th June 2008
rottenralph's Avatar
I am on my third clutch and it has 5% slip according to the dyno. I have always used sport trans up till this year when the dips!%$# stopped making it. I keep my chain set to spec and it is stretched to the max(time for a new one). my theory, we are trying to make more power than we should for the stock clutch body. the last two of mine have been barnett kevlar clutches with heavy duty spring. I do romp on my baby quite a bit. I am buying a Bandit clutch this winter most likely.
Old 8th June 2008
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
1. Year of bike - 2007
2. Model (1200/883/other) 883-> 1200 conversion
3. Miles on clutches? -> Started slipping after conversion ~ 5500 miles
4. Fluid used when slipping of clutch began? Stock (Sport Trans?)
5. How many miles on that same fluid? Never changed as far I know.
6. Did you perform routine adjustments per the service/owners manual? Probably not.
7. Your riding style: Aggressive, semi-agressive, normal, and easy going - Probably in the aggressive category?
Not sure if I'm really a good candidate to get information from, but there you go. The clutch slipped after the conversion (883->1212 NRHS, Stage 2 883 Heads, 497 cams). Replaced the stock clutch with a Barnett Scorpion...now with over 25,000 miles on this clutch, I just can't IMAGINE having an issue with it. Well, besides the incredibly INSANE lever pull...
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 8th June 2008
Lynk's Avatar
Well, my clutch looked okay when I took it out of the basket tonight. Then I noticed that the friction plates in the middle of the pack had some gouging. Seems that one of the rivets in the spring plate broke, and the two pieces were ripping up the pads.
Oh well. Seeing how much meat was left in that pack, I'm convinced that the OEM clutch isn't designed for anything more than a pipe and airbox. If you're going to upgrade, price in a performance clutch pack.
Old 8th June 2008
bplinson's Avatar
bplinson bplinson is offline
The XL Forum Host
Sportster/Buell Model: 883>1250 Stage 2
Other Motorcycle Model: Road Glide
Other Motorcycle Year: 2011
bplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond repute
1. Year of bike - 2002
2. Model (1200/883/other) 883-> 1250 Stage II conversion
3. Miles on clutches? -> Started slipping after conversion ~ 25500 miles
5. How many miles on that same fluid? 10000.
6. Did you perform routine adjustments per the service/owners manual? Have not adjusted the clutch cable but changed fluid.
7. Your riding style: Aggressive, semi-aggressive, normal, and easy going - Semi-aggressive.
Took the bike to my indy Big-V American Motorcycles yesterday to install the new clutch I got from NRHS Performance. I putting in a medium spring plate and have added an EZ-Puller to the clutch.
I am using DP-Brakes clutch plates and the rest of the parts are from Drag Specialties.
I can't justify spending $500.00+ on a Barnett Scorpion.
I should have the bike back on Thursday or Saturday.
AMA #961454
Old 8th June 2008
Phaedrus's Avatar
This is exactly what happened to mine as explained by my Indie over the phone.
Old 8th June 2008
xllent01's Avatar
xllent01 xllent01 is offline
Sportster/Buell Year: 01
The stock clutches are weak at best for aggressive riders..........that goes for any bike..........best to do an up-grade to better plates and stronger springs!!
RTFS
Ride That F'N Sportster!!
Old 8th June 2008
XLXR's Avatar
XLXR XLXR is offline
06 1200R
17,500 miles
Amsoil 20w 50 with 1,500 miles since last oil change
I do all my own maintenance. I had adjusted the primary chain, but did not adjust the screw under the derby cover.
The rivits on the spring plate sheared off. I replaced the spring plate with 1 stock friction plate and 2 steel plates. It took awhile to get used to the feel of a quicker clutch, but now I like it much better. It also shifts much better. The old friction and steel plates all looked almost new with no signs of burning or wear.
Here is the link with more details. Take a look at the Energy 1 friction plate, the friction material is off center. I sent it back and did not use it. There is also a picture of the blown spring plate.
http://xlforum.net/forums/s...d.php?t=168162
