0 question for our machinists
Last Post: Yakcm2
0 Fact or fiction?
0 Race tracks are harsh environments
0 You can't tour on that!!!
Last Post: RDHenley
Last Post: herostar
0 Black Friday/Cyber Monday Showoff Thread
Last Post: herostar
0 XLCH Plunger Seat Kit
Last Post: FatboyBill
0 hi all
Last Post: early iron
0 Swingarms
0 the roadster make more power ?
0 supply oil line seeping
0 Question on priming motor for kickstart
0 Interview of My Expieriences Riding in the Iron Butt Rally
0 Hydraulic Lift For XL
0 3.5" straight riser
0 Cometic Air Cleaner Gasket?
0 Fork Upgrade to 39mm. Is This Possible/Wise
0 Very Loud Backfiring (among other things)
Last Post: Nacs
Old 23rd May 2007
nightster 1200's Avatar
nightster 1200 nightster 1200 is offline
nightster 1200 is an unknown quantity at this point
Default 10 inch apes
does anybody know where i can get a set of 10 inch ape hangers for a narrow glide front end. they are for my 07 nightster so i would like to get some black pouder coated ones if possible. i know licks has the z bars, but i would prefer the traditional apes.
Old 24th May 2007
whittenc's Avatar
whittenc whittenc is offline
Sportster/Buell Model: XL883L
whittenc is an unknown quantity at this point
Easy option to consider for a similar effect-- I just changed my risers to 4" and got the same grip height as mini-apes. Saves the powder coat cost and has a great look with narrow glide.
Old 24th May 2007
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
J&P Cycles 12" Narrow Glide low price http://www.jpcycles.com/productgroup...3-9FC5EE937553
Licks: 12" or 16" Black PC Apes $139.00 http://www.lickscycles.com/catalog/p...roducts_id=128
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
Old 24th May 2007
i have 4.5 inch pullback risers on already, but the speedo is to upright for my likeing. it stands out to much for me. i want it down low.
Old 24th May 2007
Gone Gone is offline
Banned
Gone is an unknown quantity at this point
Try Flanders. Sorry, I don't have the link.
Old 24th May 2007
i want 10 inch apes so i dont have to change any lines or cables and then im still in warranty. 12 inch apes and i will have to get new lines and cables, no warranty.
Old 24th May 2007
SportyJoe's Avatar
SportyJoe SportyJoe is offline
Sportster/Buell Model #2: Dyna Street Bob
SportyJoe is on a distinguished roadSportyJoe is on a distinguished roadSportyJoe is on a distinguished roadSportyJoe is on a distinguished road
I know that these arent labeled for a Narrow Gluide, but have you considered the 10" mini apes that are on the Street Bob?
2007 Dyna Street Bob (Black) 12" Apes, Forward Controls, Direct Link Race Tuner, Ness High Flow Air kit, Vance Hines Straight Shots, and more to come
Gone to the "Dark Side"
Old 24th May 2007
streetfighter1's Avatar
streetfighter1 streetfighter1 is offline
Sportster/Buell Model: 3
Other Motorcycle Model: Triumph Bonny
Other Motorcycle Year: 70
streetfighter1 is an unknown quantity at this point
Have your dealer set you up with Genuine H-D parts and do the install if your worried about your warranty.
Old 25th May 2007
so does that cost the left nut, or the right one, both?
Old 25th May 2007
Bill2's Avatar
Bill2 Bill2 is offline
Bill2 has disabled reputation
Changing out handlebars or to longer cables want void your warranty.
