10th August 2015
Posts: 49 Sportster/Buell Model: 883L Sportster/Buell Year: 2012 Sportster/Buell Model #2: 2002 standard SFT tail
tires
I have the 2012 Sportster, Super low...17' on the front and 16' on the rear with mags.... radials ..... factory tires....
Looking for replacement suggestions ... as you know the Super Low is ...well low...and I am also mulling over the idea of raising the front end a bit....
so I am wondering if a higher profile tire would do the trick .. or should I extend the front end...
These are the first mags I have had .. and I like em' but the tires themselves .. shipped with the bike .. MOCO installed ....seem slippery
Just tossing around ideas for now so anything would be welcomed....
I am also in Beijing china so any choice I make can be a chore to receive unless made and sold in China.. otherwise I need to go to Hong Kong ... or ship to China....but saying that I could also come back to New Orleans to pick em' up ......
10th August 2015
Posts: 21,970 Sportster/Buell Model: XLH 1200 Sportster/Buell Year: 1993 Other Motorcycle Model: Moto Guzzi California EV Other Motorcycle Year: 1998
You can't have factory tires with a 17" front wheel. Stock factory is 19 inches. A higher profile tire will not make any difference. Or, at least not that anyone could notice, your talking 1/8 of an inch?
If you want to raise the front end, you should replace the springs in the front forks. Might at the same time check on replacing and increasing the length of the rear shocks (stock shocks are terrible).
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
10th August 2015
sorry read wrong.... Michelin Scorcher 11F 120/70ZR18 front & 11 150/60ZR17 rear
10th August 2015
jharba thanks for that rear shock advice...
10th August 2015
Posts: 9,555 Sportster/Buell Model: None Sportster/Buell Year: None Sportster/Buell Model #2: 883C/883H/883R/1200C-sold Sportster/Buell Year #2: many Other Motorcycle Model: Dyna FXD-sold Other Motorcycle Year: 2004
Jar - It's the superlow.
Tires, Front Specification 120/70 ZR-18 59W
Tires, Rear Specification 150/60 ZR-17 66W
Not 17, but not 19 either. Anyway - the tire profile will be nominal, like Jar said.
10th August 2015
ok... so if'n' I keep this set up .. what is a good tire for the Low
10th August 2015
My screw up. Was starting to confuse it with another post I was also working on.
