0 All balls generator
Last Post: jeffro57
0 Factory Chain Oiler
Last Post: tiderider
0 Gas Cap problem?
0 Top end tapping products
Last Post: RandallM
0 Bike issue after swapping handlebar. :(
Last Post: slonez
0 Oil pressure sensor question. Is it no good?
0 1981 XLH Getting Recranked
0 Regulator contacts welding shut
0 New Top Fuel record
Last Post: owlsplace
0 VIeds advice...
0 XR caliper on Iron
Last Post: FuriousGeorg
0 DC Regulator wiring Accel 201102
Last Post: 72 Ironhead XLH
0 Clutch biting point
0 93 sportster when throttling up shuts off?
Last Post: Fivecats
Last Post: lehel
Last Post: Kzac
0 Only one breather bolt breathing?
0 ELectrical Issue 96 xl1200s
0 81 sporty 4 speed install ?s
Last Post: class of 82
0 Fork Gaiters
0 Clutch Spring plate poll
george (67), mwndragon (65), angusiw76 (46), XxValDeexX (41), ELPYRO (40), a175 (40), rolliphilip (31)
battery box, chopper, hardtail, oil tank, rigid
Old 2nd September 2021
Kickflippin Kickflippin is offline
Sportster/Buell Year: 1976
Other Motorcycle Model: Yamaha XS650
Other Motorcycle Year: 1978
Kickflippin is an unknown quantity at this point
Default Paughco single loop frame mounting ideas
I'm trying to find a good looking way to mount up a battery and oil tank to this Paughco single loop frame. Dropping a '91 motor in it. I was hoping to get the battery into a BT horseshoe tank I already have but nothing really lines up without having to place a bunch of mounting tabs for support. plus it sticks out too far on the sides.
I can track down a cylinder style oil tank, which will be alot easier to mount, but this frame doesn't leave much room to mount a battery in front of the rear fender, Also, the fender support is angled so event a small battery sits crooked.
I know this is simple stuff but I'm just out of ideas for now. Appreciate it. And... sorry for the giant pictures.
Old 3rd September 2021
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Well. All I can post is my mockup . Everything mounts behind the center post anyways . Whether single downtube custom hardtail or stock weld on hardtail on stock frame.
Edit: For a battery idea. That battery you show us overkill < Godzilla>. I'd look into getting smaller lithium battery myself. With lots of cranking amps.
Traveled to
zimbros12's Avatar
zimbros12 zimbros12 is offline
Sportster/Buell Model: XLH 1200 Hardtail
zimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to beholdzimbros12 is a splendid one to behold
kitabel kitabel is offline
Sportster/Buell Year: 1989
I can't quite see the individual molecules, need bigger pictures.
Les59 Les59 is offline
Sportster/Buell Model: xlh1100
Sportster/Buell Year: 1986
Les59 is an unknown quantity at this point
If it absolutely won't fit anywhere else I would be tempted to strengthen and modify a swingarm bag and put it there.
Old 12th September 2021
Uberstorm Uberstorm is offline
Sportster/Buell Year: 1979
Sportster/Buell Model #2: ironhead
Sportster/Buell Year #2: 1979
Uberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud ofUberstorm has much to be proud of
i built a belly pan and fitted a litium in there and alarm n charge point etc, i also added a on off switch so i dont have to remove the belly pan if i need to do some electrical work. Fuses in the head mounting
http://xlforum.net/forums/attachment...3&d=1631405508
You may find that seat + position impractical. As the coil springs compress, you slide off the back. That's why seats are usually angled up in the rear, have a raised back, or both.
Old 13th September 2021
bill smith bill smith is offline
Sportster/Buell Year: 1971
bill smith has disabled reputation
cut that lower fender support out and start over. you can incorporate a fender support into the battery box/tray. just make sure you can slide the batt. out the left side easily.
Old 14th September 2021
Andy Hog's Avatar
Andy Hog Andy Hog is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: 1964 Triumph 3TA
Andy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant future
Hi,
have you considered putting the full motor in the frame & seeing if a horseshoe oil tank that has the battery compartment integrated in to it will fit behind the engine?
Andy.
Paughco May be able to make recommendations?
Pleasing everyone is impossible but pissing everybody off is a piece of cake!
