Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Bottom End
0 Do not buy this oil!
0 New oil tank
0 XLCH 900 1969 Build Thread
Last Post: K2019
0 Hi everyone
Last Post: jharback
0 New member
Last Post: jharback
0 newbie
Last Post: jharback
6 Hello Folks
Last Post: jharback
14 Buell back in business?
Last Post: Eugis
0 Ironhead Exhaust Poll
0 excellent color
0 random rattle
0 top end rebuild
Last Post: eisenhead
0 WTS: Forward Controls 2004-13
0 New Harley CEO
0 Vulcan Mid Glide Triple Tree Conversion Set
Last Post: Dariusz
Last Post: Marsikus
0 Bike wobble question
0 Clutch blow up
0 Stock vs. Modified
patc, Camera108 (67), pbudrovic (65), Rob Roy's Revenge (64), gene04 (63), guvnor (56), jrogers329 (50), ksoggs (45), dmurphy68 (43)
Old 4th November 2012
tommyp tommyp is offline
Sportster/Buell Model: 1200 xl
tommyp is an unknown quantity at this point
Default I got a cracked crank case looking for a couple answers
I wrecked my bike and cracked the crank case I am pulling the engin off to chang it out the question I have is will I need to change out the tapplets since I am replaceing the case? is there any other advise I can get while I got the motor out any advise is apprecieated.
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Tappets won't need to be changed.
Set your flywheel end play ... there's a shim between the two timken bearings on the left side.
Select the correct pinion bearing. Two precise measurements and a table in the service manual are involved.
Upgrade your primary tensioner and your oil pump drive gear if you haven't already done so ... both are weak points.
Check your cams for proper fit. '99 motors had fitted cams and moving cams from one motor to the next requires making sure they still fit properly.
Torque your cam cover in the proper sequence, it's important.
Do your pawl adjustment correctly.
Torque your cylinder studs correctly. Flanges down, red thread locker. Oil your head bolts and torque properly.
Just take it step by step, make sure you do everything correctly. The service manual is your friend, get one if you don't already have one. It does a good job of giving you proper procedures.
Click Here to Contact Me
Thanks aswracing for the tips I will be sure to follow. I am pretty close with my manuel.
thanks Bob
BUMP[/QUOTE]
