0 Diagnostic help
Last Post: BradX13
0 900 heads contd..
Last Post: spacecoast
Last Post: wharg
0 Bars on C Riser?
0 Clutch Spring plate poll
Last Post: jammantoo
0 Future of the sporty?
0 crack in head
Last Post: slamtry
Last Post: 883openpipes
0 the far west burbs of Chicago
Last Post: jzink0883
Last Post: lugster
Last Post: BrokenIron
0 More of a reintroduction
Last Post: lugster
0 05 and 73
Last Post: TT60
0 Racing tem up with Hero moto corp
Last Post: retired
0 The White Bike is the Right Bike Thread.
0 Starter motor
Last Post: sleighcrane
0 Found my bike on Google maps
Last Post: gravydog
5 Am I looking for Trouble ?
Last Post: Crosshairs
0 WTF Happened
Old 16th July 2015
Ricko#01 Ricko#01 is offline
Sportster/Buell Model: Xl1200 custom
Ricko#01 is an unknown quantity at this point
Default Loose negative battery connection
Hello, my bike is a 2009 1200 custom. Recently on a ride lost power (engine). While this happened the speedometer dropped down to almost 0. I hadn't slowed that much. Power loss was brief and sporadic. Also stopped at a light and the engine and battery light came on. I made it home.
Checked the battery (its pretty new) the negative terminal was lose. Tightened it up and used some lock tight. Im thinking this was the problem. Havent taken a ride yet. A little nervous. Does this sound a likely fix for this issue and does anyone have other (trouble shooting ) suggestions to look into. Thanks for any help. ricko
Old 16th July 2015
ReddTigger's Avatar
Loose and corroded cables are a common source of problems. Take it for a spin.
You will at least know that its not the cables..
But the symptoms match a bad cable.
States I've Ridden in
71.3 hp 70.8 tq
Old 16th July 2015
Thanks, im hoping thats it. Ill take it out tomorrow and see what happens. Nice bike.
Old 16th July 2015
Welcome to the forum family from a swamp in Michigan. You can also add a small zip-tie around the battery post and cable end, helps a lot keeping things tight.
Old 16th July 2015
Thanks sportsterpaul. Im in a swamp in south jersey. Used to live in kalamazoo. Thanks for the zip tie tip. If the locktite fails i'll try it.
Old 16th July 2015
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Welcome to the forum from sunny Italy and another former Kalamazooan.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 16th July 2015
Welcome from Missouri. I had the most trouble with the ground to frame connection.
Old 16th July 2015
Mosey Mosey is offline
Sportster/Buell Year: 1982
Other Motorcycle Model: FX
Other Motorcycle Year: 1976
Mosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond reputeMosey has a reputation beyond repute
I've never used Loctite on battery connections. It's a good idea once or twice a year to put a wrench on every fastener. These old Milwaukee vibrators are constantly attempting to shed parts...
Old 16th July 2015
sportsterdoc's Avatar
Other Motorcycle Model: Honda CB1100
Other Motorcycle Year: 2014
Very true on all points.
Old 16th July 2015
Ditto on the welcome. The negative to frame/motor is THE most common electrical issue on decades of Sportsters.
