0 WTF Happened
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
0 Cylinder Piston kits
Last Post: jordan1200
0 05 and 73
0 What is this?? 07 efi 1200 weird box
Last Post: Hank21113
0 Brake light stays on
Last Post: jammantoo
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
0 Tool Roll Help
Last Post: ReddTigger
Last Post: blindfredy
0 S.Fla. shop
Last Post: the cowboy way
0 Back in Sporty Land
Last Post: skien
Last Post: The Crusher
  #61
Old 18th July 2015
DTSKVstar1100 DTSKVstar1100 is offline
DTSKVstar1100 is an unknown quantity at this point
Looking to change out an ignition module, old style 34265-98 for a new Dynatek DS6-1.
my problem is the old one has 5 wire to a molded plug the new one has 2 wires. I would appreciate any wiring help on this one.
bike is a 1998 Harley Davidson Sportster 1200. thanks in advance for any help
Rick
Old 18th July 2015
sportsterdoc's Avatar
Other Motorcycle Model: Honda CB1100
Other Motorcycle Year: 2014
Rick
I do not have a 98 schematic to advise color numbers (different from a Sport), but this link is for the instructions.
http://www.manualslib.com/manual/396...tek-Ds6-1.html
The white wire connects to switched power, typically white/black. The instructions advise connecting to the + side of the coil primary, but you can connect to anywhere on the ignition circuit switched power white/black wire on the load side of the off/run switch. One of the 5 wires will be that white/black.
The blue wire connects to the wire from the - side of the coil. On a Sport or 2004-2006 there are two wires, the colors are y/be and be/o. Check your FSM schematic for the appropriate color. Without a FSM or year appropriate schematic, a continuity tester or ohmmeter can determine the correct wire from the coil.
DO NOT REVERSE THE WIRES OR IT WILL DESTROY THE DS6-1
