Last Post: treerat01
0 Rocker shaft locks
Last Post: Brendenhrvy
Last Post: screndname
0 front wheel speedo box
Last Post: Roaldl
0 79 carb question
Last Post: chaz
0 starter clicking
Last Post: chaz
0 Speedo cable hunt
0 .551 Cams in an EFI 1200
Last Post: boonoorong
0 1989 oil filter lines
0 speedo drive for 1979
Last Post: chaz
0 supply and demand
Last Post: spoon
Last Post: Kingrabbit
0 Rocker Lockers - Quiet Down Annoying Top End Ticking
0 Spray on water resistance
0 Kehin carb spray nozzle
oldsporty1 (73), paris15 (65), thesmithiz (65), pajimmyjoe (64), chuckam (60), steve w (54), le_strike (47), Rubicon (41), r3db3ard3d (35), rortiz76 (35)
bendix, removal, starter clutch
Old 24th March 2012
Jray's Avatar
Jray Jray is offline
Sportster/Buell Model: Xlch
Sportster/Buell Year: 77
Jray is an unknown quantity at this point
Angry 77 xlh starter clutch removal
Alright folks, I have been through the threads, through the Haynes manual and I am still havIng a problem replacing the starter clutch. I've got the left hand thread retainer off, the part behind that is off, so now I'm to the starter clutch and can't get it out. What's the deal. The manual says it should just pull out but the bearing is hitting the clutch gear.does the solenoid arm need to.come out first? Beautiful weather and this problem is grounding me.
Thanks
Old 24th March 2012
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
remove the battery, notch the bottom of the battery tray to remove the bolt that holds the arm in place, remove retaining pin, cup, spring from arm,remove bendix gear.
Old 24th March 2012
Originally Posted by 72 Ironhead XLH View Post
... remove the bolt that holds the arm in place, ...
You most likely need an impact driver, the kind you hit with a hammer, to remove this bolt. I would not try to remove it just with a screwdriver.
Old 27th March 2012
Jrayokla Jrayokla is offline
Sportster/Buell Model: Xlh
Jrayokla is an unknown quantity at this point
Alright, feeling pretty dumb/annoyed. Got the solenoid arm out but can't get the starter clutch past the clutch basket, tried this from another thread but still cant get it out. Any other suggestions or clarification on the instructions below?
To remove the pinion..
Move the shift fingers out of the groove on the shifter collar by moving the end of the shifter lever forward.
Then remove the pinion assembly...
