0 1983 Ironhead! No Spark
Last Post: God of Thunder
0 Keihin carb…mixture screw
0 Ran out of gas.
0 Hello from Cape Cod
0 New to Harleys
0 Turn signals won't work when cold
Last Post: Debute23
0 Major update forthcoming
0 Cafe' Image thread WTFN
Last Post: tigger
0 2013 XL883L Electrical Question
5 Not charging, new Reg w/weird readings
Last Post: spoon
0 Turned down by a Tattoo Artist
Last Post: Deimus
0 Does Yankee Engineuity still exist?
Last Post: ReddTigger
0 The adventure of bringing my Sporty from Italy to Denmark
0 Question about our school systems
Last Post: delcrossv
0 Cams for Alcohol (E85-E98)
0 Front end assembly questions
Last Post: Kit352
0 Tachometer wiring/speedo hookup
Last Post: BigMek
0 Vacume gauge questions
Last Post: Fivecats
0 Need a mechanic
Last Post: Big_Baazzoo
0 Nick in piston causing my head gasket leak?
Last Post: JB in NC
0 Mikuni carb tuning issue
0 Guide to Swingarm Bearing Replacement
Last Post: JB in NC
DaddyJay, cartoad2001 (74), Dirty Ernie (68), ncpickman (62), bri1200c (60), pquirk (57), GOTWA (54), gremlinsteve (54), lbowles2 (52), Guess (44), rnaway22es, blueandy88 (40), landon283 (35)
1970, clutch, ironhead, transmission
Old 19th July 2016
Sportster/Buell Year #2: '03
broken pawl spring is another possibility.wait for other responses.
72 1000cc barrels and XLR heads, S&S 4-1/2'' flywheels, sifton minus-minus cams, S&S super A w/ zippers thunderjet w/yost powertube, Andrews gears,and shafts, 72 oil pump, Morris magneto w/auto advance and single fire module, cycle electric generator w/electronic regulator,73 cu.in.
Old 19th July 2016
if you have the old style pawl carrier assembly (used until '71) that are notorious for getting gummed up over time.
Old 19th July 2016
Automodown Automodown is offline
Sportster/Buell Model: xlch 900
Sportster/Buell Year: 1970
Other Motorcycle Model: Dyna
Automodown is an unknown quantity at this point
Good question. I have never opened up the transmission so I am not sure. What would be an indicator once i get in the transmission that might be the problem?
Old 19th July 2016
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
For troubleshooting purposes try gently tapping on the end of the shift shaft to see if it frees up.
Try tapping with lever up and down.
Old 19th July 2016
DR DICK DR DICK is offline
yep.
nylon from skidshoe binding the downshift plunger in its bore.
Old 19th July 2016
Before tearing into it, spin the rear tire with feeling.
It may have shifted but the dogs are not engaged and the wedged dogs have the shifter in a bind.
Rotating the rear wheel backwards smartly may get the dogs to drop in and unjam the shifter.
Old 19th July 2016
Chevelle, DR Dick and everyone else that helped me ...THANK YOU! Tapping on the shift shaft did the trick. The sucker went right into third after a few good taps. Is this something that might turn into a problem down the road? Thanks again!
Old 19th July 2016
change your oil/primary fluid changed regularly, and if you haven't been inside the primary, it might be a good idea to have a skid shoe for the primary chain on hand to replace the old one...
Old 19th July 2016
Funny thing is I just changed the oil right before this happened. The primary shoe and all clutch components are all new. I replaced almost everything on this bike at one point or another minus the generator and carb. Thanks for the advice! I am just glad I didn't have to tear into the tranny.
