Snippets
Last Post: Dusz
moe (79), demgdaj (73), Playtoe (68), shanneba, Charlie Allen (64), the cowboy way (64), P-Diddly (61), Utahsporty (60), evo-pete (59), stf420 (58), NevadaRob (56), Punisher (54), Razor_Reznor (49), Paycheck (46), jfs92579 (44) |
13th November 2020
Posts: 2,995 Sportster/Buell Model: xl883n Iron (2019 engine) Sportster/Buell Year: 2017 Sportster/Buell Model #2: xl Hugger (sold) Sportster/Buell Year #2: 2001
Updates
still no answer from RSD USA
not that i was confident in one...
i have updated even the retailer on the net where i bought it... about this issue...
so he contacted me today... and told me that his RSD contact here in Italy will give him another polycarbonate Lexan window asap to send me for free...
13th November 2020
Posts: 124 Sportster/Buell Model: XL1200X Sportster/Buell Year: 2012 Other Motorcycle Model: Road Glide CVO Other Motorcycle Year: 2009
I have a fix suggestion for the new one, before it breaks.
Enlarge the bolt holes using needle file, just slightly, to prevent being pushed when aluminium expands, and use thin o-rings underneath the lexan to give it a little more support. Ideally the o-rings should be level with the sealing gasket or slightly thinner.
Torque just enough to slightly compress the seal, and relay on loctite rather than torque to keep the bolts from unscrewing.
I guess that the breaks happen due to combined action of side pressure of aluminium expansion, and lack of support around the bolt holes.
Hopefully, should last more than one summer.
13th November 2020
Thanks... i am considering seriously something like that... my final goal though would be armoured glass...
13th November 2020
Yeah, we live in age of plastic.
50's and up to 80's Soviet military diving suits had no umbrella exhaust valves...they were ground glass supported by stainless spring.Just like old fashioned bottles for storing chemicals, ground glass surface on neck and plug.
These days, cost of such application would be rather prohibitive.
13th November 2020
MetalWorkingXLFan
Posts: 741 Sportster/Buell Model: XL1200V Sportster/Buell Year: 2013 Sportster/Buell Model #2: KHK Sportster/Buell Year #2: 1954 Other Motorcycle Model: Valkyrie Other Motorcycle Year: 97
I just have to think that polycarbonate would be vulnerable to hydrocarbons and additives in the trans oil. When stuff reacts you get cross linking of molecules and property changes that will show up as stresses and cracks. I’m thinking that quartz or borosilicate glass would be the best choice. Machining and finishing would be a whole different animal.
If your local connection comes up good with the replacement that’s great. If not you need some of that aluminum plexiglass from the Star Trek movie with the whales.
13th November 2020
my dad once knew a guy, now retired, who carved for him a Ferrari's rampant horse from a single 50 cm block of thick tempered glass... using a high pressure water/sandblast saw... nowadays these jobs are like a virgin in an harem...
13th November 2020
true...
in addition a true glass does expands along alum when hot...
some millenials are hoping for the end of the plastic era as well... much better glass...
13th November 2020
Posts: 16,992 Sportster/Buell Model: XL1460C Sportster/Buell Year: 2000 Sportster/Buell Model #2: XL1200R Sportster/Buell Year #2: 2006 Other Motorcycle Model: XL1200R Other Motorcycle Year: 2004
Well while I’m pleased that someone has a replacement coming for you, it will of course fail like the first one unless some type of modification is performed. Do keep us posted, thanks.
14th November 2020
Posts: 7,415 Sportster/Buell Model: XL77.2R Sportster/Buell Year: 2006
Go to a vitrail shop, stainglass craftsman and get what you need.
14th November 2020
not so simple overhere
