Last Post: JB in NC
0 Rocker shaft locks
Last Post: screndname
0 front wheel speedo box
Last Post: Roaldl
0 79 carb question
Last Post: chaz
0 starter clicking
Last Post: chaz
0 Speedo cable hunt
0 .551 Cams in an EFI 1200
Last Post: boonoorong
0 1989 oil filter lines
0 speedo drive for 1979
Last Post: chaz
0 supply and demand
Last Post: spoon
Last Post: Kingrabbit
0 Rocker Lockers - Quiet Down Annoying Top End Ticking
Last Post: Brendenhrvy
0 Spray on water resistance
0 Kehin carb spray nozzle
oldsporty1 (73), paris15 (65), thesmithiz (65), pajimmyjoe (64), chuckam (60), steve w (54), le_strike (47), Rubicon (41), r3db3ard3d (35), rortiz76 (35)
4th gear, gearbox, ironhead, sportster, transmission
Old 6th September 2022
Check how much slop exists between the cam plate axle and the shift tower bore where the cam plate rides inside. The spring loaded cam follower is always pushing the cam plate away from the trap door. If there is too much clearance in the tower bore to axle fit the cam plate will turn off axis and wear the top hats down or crack them. You’re lucky that broken piece didn’t travel between meshing gears!!
Old 9th September 2022
Yamalol Yamalol is offline
Sportster/Buell Year: 1981
Sportster/Buell Model #2: 1957
Yamalol is an unknown quantity at this point
New problem: I put everything back together (details below) and went for a ride. I can shift into 4th now without issue, but as soon as I let the clutch out I can hear chatter from the trans and get a lot of jerkiness like it's popping in and out of gear. I adjusted the clutch per the manual, and it was fine in gears 1-3.
Any ideas?
Instead of replacing the top hat, I replaced the entire shifter assembly with the one from my parts transmission. Looked to be less wear, and the tophats had a little less play. All of the gears looked fine. No noticeable wear or chipped gears.
Sportster/Buell Year: 1972
Did you take the gears off the shafts and give them all a good look over?
I did, nothing had any noticeable wear, and definitely nothing as noticeable as chipped teeth.
How fast are you traveling when you shift into 4th? I do north of 50mph when I upshift to high gear… try another clutch adjustment and see if it still does it?
Old 10th September 2022
joe s joe s is offline
Sportster/Buell Year: 72
Sportster/Buell Year #2: 71
Other Motorcycle Model: Five Harleys
joe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud ofjoe s has much to be proud of
If this was a BT 4-speed trans I'd ask if the new shift yoke had the same shims as the old? IDK if that applies to sportster?
Old 23rd September 2022
Alright, I pulled the transmission again and found some very noticeable wear on one of the shift forks. I made a video to make it clearer. Linked below. Any help greatly appreciated.
https://www.youtube.com/watch?v=DSWU3MfAGAY&t=12s
Ok I kind of answered my own question. I didnt notice on the video, but the dogs on the clutch gear and female side of the 2nd gear arent great. I'm going to replace both, but is there any thing else I should take note of?
Thanks for putting that video up. That clutch gear does look sketchy to me.
Sportster/Buell Year #2: '03
you didn't notice likely because you're inspecting your trans. parts while they're still covered in oil.that should all be removed before inspecting.i'm going to come back later and have another look at your video.
72 1000cc barrels and XLR heads, S&S 4-1/2'' flywheels, sifton minus-minus cams, S&S super A w/ zippers thunderjet w/yost powertube, Andrews gears,and shafts, 72 oil pump, Morris magneto w/auto advance and single fire module, cycle electric generator w/electronic regulator,73 cu.in.
