Last Post: treerat01
0 Rocker shaft locks
Last Post: Brendenhrvy
Last Post: screndname
0 front wheel speedo box
Last Post: Roaldl
0 79 carb question
Last Post: chaz
0 starter clicking
Last Post: chaz
0 Speedo cable hunt
0 .551 Cams in an EFI 1200
Last Post: boonoorong
0 1989 oil filter lines
0 speedo drive for 1979
Last Post: chaz
0 supply and demand
Last Post: spoon
Last Post: Kingrabbit
0 Rocker Lockers - Quiet Down Annoying Top End Ticking
0 Spray on water resistance
0 Kehin carb spray nozzle
oldsporty1 (73), paris15 (65), thesmithiz (65), pajimmyjoe (64), chuckam (60), steve w (54), le_strike (47), Rubicon (41), r3db3ard3d (35), rortiz76 (35)
clutch spacing, pressure plate, spacing
Old 12th August 2022
Hardtail28 Hardtail28 is offline
Sportster/Buell Model: Sportster 1000xlh
Sportster/Buell Year: 1979
Other Motorcycle Model: 1975 cb750
Hardtail28 is a name known to allHardtail28 is a name known to allHardtail28 is a name known to allHardtail28 is a name known to allHardtail28 is a name known to allHardtail28 is a name known to allHardtail28 is a name known to allHardtail28 is a name known to allHardtail28 is a name known to allHardtail28 is a name known to allHardtail28 is a name known to all
Default Clutch spacing 1979 1000xlh
So I am about wrapping up on the transmission job.. I am now putting back on the clutch's pressure plate. I (believe) that you measure from the inside shoulder of the "pressure plate" to the "outer drive plate" .... my book, a clymber, says that '74 and later are different.. however, it does NOT say what the distance is supposed to be. I should NOT tighten all-the-way to the spacers, correct?
1Scooter 1Scooter is offline
Sportster/Buell Model #2: 2004 XLH1200Custom
Other Motorcycle Model: 2007 FXDB
1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of1Scooter has much to be proud of
My FSM only goes up to 78. Standard spacers are 1.530 and 1/8" is the proper clearance. I would just tighten down the nuts and measure to be sure it's on the spot.
Ok, so I was actually told "at least 1/8 before reading.. at 1/8 and an additional 1/16, I am all the way tightened (down to spacers) I let all the tension from the "clutch spring tension tool" as, I am fairly sure that you would not want any tension on the pressure plate (when tightening the 6 nuts to gauge the pressure asserted on the springs).
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
You tighten down just till the nuts start to snug up when the plate touches the spacers
Ez to crush the spacers, so be gentle.
Use a nut driver so you don't overtighten.
Use new nylock nuts.
Old 13th August 2022
Well again fearing that I screwed up once more as I had already kinda "snugged" up a little too well. I checked the spacers and they don't look distorted or crushed.. I did just come back from ace hardware in taking Ryder Rick's advice and got some new nylons.. I was just going to use high-strength honda lock. But anyways... back too work!!! Thanks amigos!
