0 Seneca Shadows WV. Sept. 5th to 8th and maybe beyond.
0 Keihin carb…mixture screw
0 1st gear clutch squawk
Last Post: OCRyder
0 supply and demand
0 73 XLCH help
Last Post: JB in NC
Last Post: JB in NC
0 Major update forthcoming
0 Vacume gauge questions
0 Rear wheel offset?
0 Question about our school systems
0 Ran out of gas.
0 Hello from Cape Cod
Last Post: xena
0 New to Harleys
Last Post: Dusz
0 1983 Ironhead! No Spark
0 What engine oil do you use?
0 Turn signals won't work when cold
Last Post: Debute23
0 Cafe' Image thread WTFN
Last Post: tigger
moe (79), demgdaj (73), Playtoe (68), shanneba, Charlie Allen (64), the cowboy way (64), P-Diddly (61), Utahsporty (60), evo-pete (59), stf420 (58), NevadaRob (56), Punisher (54), Razor_Reznor (49), Paycheck (46), jfs92579 (44)
slip-ons, stage 1 exhaust
Old 21st April 2023
G-dizzle G-dizzle is offline
Other Motorcycle Model: Heritage Softail Classic
G-dizzle is an unknown quantity at this point
Default Are Screamin' Eagle Part Number: 80518-07 Slip-Ons stage 1?
I have a 2010 xl1200c with Screamin' Eagle Slip-Ons. The Part Number for the rear is 80518-07, the part number for the front is 80599-07. I'm trying to figure out if they are stage 1. The new ones on the Harley site are Part Number: 80503-07. The bike has the stock air cleaner & filter.
Any help is greatly appreciated.
Old 21st April 2023
Derr! sorry, I figured it out. The part number on the Harley site (80503-07) is for the pair and they ARE stage 1. thanks anyway.
Old 25th April 2023
Melnic Melnic is online now
Sportster/Buell Model: XL 883
Other Motorcycle Model: Yamaha XJ650 Maxim
Other Motorcycle Year: 1983
Melnic is an unknown quantity at this point
I have same pipes on my 2007 and one questions I have for you is does yours misfire some when you are letting up on the throttle and going down a hill in a lower gear? I hate how mine sounds as if the engine is not running right. Don't know if that is typical/normal. This is my first sportster and it was used and came with the SE slip ons.
Old 25th April 2023
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
See the test on those slip-ons here: http://www.hammerperf.com/ttxlexhaust.shtml#sespslipons
Click Here to Contact Me
Old 25th April 2023
Thanks aswracing. That helps a lot. Do you think i could remove the baffles to increase the air flow preventing it from dying early and level out a little higher?
Old 25th April 2023
aswracing's Avatar
Exhaust design is pretty complicated. There's a lot more to it than just pumping losses from restriction. For example, pressure wave travel has an enormous effect. So a simple change like what you're describing may help in one way and yet hurt in another.
Bottom line, I hate to speculate on what effect any given change might make. The dyno has a way of making me look really foolish when I do that.
Old 25th April 2023
Thanks again, i spoke to the service tech at Boswells Harley dealer and he said basically the same thing so I'm just gonna leave them alone.
