0 Saddlemen step up seat on 07-09
Last Post: mastiffhound
Last Post: 308bever
Last Post: Yakcm2
0 Boardtracker Project
Last Post: Yakcm2
0 Throttle cable/housing
0 Keith Black Conversion
0 Nescessary Tool Kit
0 Let's study the 77-85 oil pump, parts, and changes and when.
Last Post: DirtyCory
0 "S" model specific Q&A
Last Post: Edster
0 Look Ma - No Hands - BMW
0 Big Bore Kit - What else is needed
Last Post: farmall
0 Moto Guzzi V9 Bobber debut
Last Post: mjptexas
Last Post: Diogenes415
0 Dead battery cells - 1997 sportster 883
Last Post: Four Speed
0 Howdy y'all
Last Post: oreocat1
0 Gravydog crashed again.
Last Post: gravydog
0 Troy Corser racing 1929 BMW R57 Compressor at Goodwood Revival
0 Replacement Fuel line?
0 ‘17 Roadster no start...
5 No power to ignition, intermitently
Last Post: Medyo Bastos
0 Good kid or Bad Kid??
Last Post: FearTheBeard
0 XR-Cafe-Conversion
Last Post: tomaso
0 4D world
0 Electrical Problem with '77 XLH-no power
Last Post: 60weight
Old 13th June 2018
RussW RussW is offline
Sportster/Buell Model: Hugger
Other Motorcycle Model: Panhead
Other Motorcycle Year: 1961
RussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud ofRussW has much to be proud of
Here's a kit with caliper and bracket, fits 41mm front ends, but this company can probably make the bracket to fit just about anything
http://www.fabkevin.com/shop/parts/b...-caliper-kits/
2002 Hugger, S&S 1200 conversion, Woods cam,SE ignition/coil, D&D Fat Cat
Old 14th June 2018
jkinkade jkinkade is offline
Sportster/Buell Model: XLH 1200 2003
jkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to beholdjkinkade is a splendid one to behold
thank you all for idea's.
I want to keep bike looking stock, just motor and gear box and , Ohlins 14.5" shock custom set up to weight, Race Tech springs & gold valving in stock 39mm forks, custom set up to weight. but want to keep rest of the bike stock. so I'll use the brake pads recommended here & braded brake hose.
where I live ( Australia ) don't use brakes a lot. I ride twists but low traffic volume. also motor am building will have strong engine braking too.
thanks again, safe riding.
2003 XL1200
Old 14th June 2018
Diogenes415's Avatar
The trick is to keep your rotor and pads clean with acetone... not auto parts store brake cleaner or nail polish remover containing acetone since they can contain contaminants depending on the brand. The next in line is making sure your master cylinder and caliper are in tip-top shape...tear them down and clean them at the very least if not replace all seals... also make sure your float pins are clean and lubed. Next up if it's in your budget and you have rubber lines, replace them with braided lines. Next I would usually go down in size on the master cylinder... if you have a 9/16 piston (~14mm) then move down to a master cylinder with a 13mm piston. The lever travel will increase a little but the feel will be far more predictable and you'll probably end up with two-finger if not one-finger brakes (even my stock 2006 XL883C brake with Ferodos is a one finger affair in most traffic situations). Also, look for Ferodo organic pads... very nice pads which I've trusted to haul me from a 140mph back straight into a sharp ~45mph 90° left turn (10a) at Road Atlanta and out-braking my opponents.
I've been a huge fan of single disc brakes and R&Ding them and I'll tell ya, when it comes to road use, even the one Sportster single piston floating caliper can offer many more benefits than running dual disc setups.
Old 14th June 2018
Thank's so much for this information!
I'll do all that & look for a 13mm (1/2" ) bore master (more leverage ) & the beaded lines. I have some Acetone, so will clean rotors & pads.
thanks again.
Old 14th June 2018
Originally Posted by jkinkade View Post
... I'll do all that & look for a 13mm (1/2" ) bore master...
Did you verify that you have a 9/16 master cylinder? Incidentally here's some good info from Michael at Vintage Brake... the dude is a wiz and knows his stuff.
http://www.vintagebrake.com/mastercylinder.htm
Old 14th June 2018
Thank you again!!
I will verify if the master is 9/16 bore on Monday . the bike is at my friends work shop doing engine & gear box, nothing wrong just upgrades as planing on riding it a lot.
