Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > NRHS - High Performance
0 Timing issue
0 It's a Buyinhead
Last Post: Tin Man 2
0 Shuts down after 30 miles
Last Post: frogg_nutts
Last Post: Magneto Sportster
0 Anyone make a DIY vibrating tumbler?
Last Post: paulc
0 Transferring photos
Last Post: bplinson
0 THE Trainspotting Thread
0 where did you put your xlforum patch?
Last Post: Cropduster
Last Post: myrl883
Last Post: Scuba10jdl
0 Re 1986 ignition
Last Post: Edster
0 sommer shootout
Last Post: Racepres
0 900 heads contd..
Last Post: mrmom9r
0 Push Rod Adjustment
0 Laconia Motorcycle Rally 2018
0 Fixing a loose mirror
Last Post: Yochstein
0 Sportster security help
0 ‘68 XLCH...transmission
Last Post: DirtyHarry68
dtremaine (71), Dana (69), Shorty0064 (54), Mini Sumo (50), bikenest (50), ecjq (47), broncobilly (44), XL883L (41), Captain Awesomepants (39), calfunk (37)
hurricane, nrhs
Old 11th November 2008
FoxsterUK's Avatar
FoxsterUK FoxsterUK is offline
FoxsterUK is a splendid one to beholdFoxsterUK is a splendid one to beholdFoxsterUK is a splendid one to beholdFoxsterUK is a splendid one to beholdFoxsterUK is a splendid one to beholdFoxsterUK is a splendid one to beholdFoxsterUK is a splendid one to beholdFoxsterUK is a splendid one to beholdFoxsterUK is a splendid one to beholdFoxsterUK is a splendid one to beholdFoxsterUK is a splendid one to behold
Originally Posted by KC_Sporty_Gal View Post
That picture is exactly what my set up looks like Rod. I'm waiting for a warmer day to get back into the garage to play around with it.
Mine is similar to that.
I took the fuel pipe off the carb, removed the cover and tried it again. I found that the fuel pipe isn't close to being pinched. As its just the cover thats getting flattened I decided to not worry about it and put the cover back and I'm living with the cover lightly flattened.
Fox
I do not use the corrugated plastic stuff on my bikes. i have never had a melted fuel line.
