Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > NRHS - High Performance
0 where did you put your xlforum patch?
Last Post: tigger
0 Timing issue
0 It's a Buyinhead
Last Post: Tin Man 2
0 Shuts down after 30 miles
Last Post: frogg_nutts
0 Need a source for Ironhead shocks
Last Post: Magneto Sportster
0 Anyone make a DIY vibrating tumbler?
0 Transferring photos
Last Post: bplinson
0 THE Trainspotting Thread
Last Post: Cropduster
Last Post: myrl883
0 Can’t get upper triple tree removed. Advice?
Last Post: Scuba10jdl
0 Re 1986 ignition
Last Post: Edster
0 sommer shootout
Last Post: Racepres
0 900 heads contd..
Last Post: mrmom9r
0 Push Rod Adjustment
0 Laconia Motorcycle Rally 2018
0 Fixing a loose mirror
Last Post: Yochstein
0 Sportster security help
0 ‘68 XLCH...transmission
Last Post: DirtyHarry68
dtremaine (71), Dana (69), Shorty0064 (54), Mini Sumo (50), bikenest (50), ecjq (47), broncobilly (44), XL883L (41), Captain Awesomepants (39), calfunk (37)
hurricane, nrhs
Old 8th November 2008
KC_Sporty_Gal's Avatar
KC_Sporty_Gal KC_Sporty_Gal is offline
Sportster/Buell Model: XL883C (1235 Conv)
Sportster/Buell Model #2: XL883R
KC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to allKC_Sporty_Gal is a name known to all
Default Hurricane AC and Horseshoe breather assembly
I am in the putting on the hurricane and horseshoe breather. According to the instructions I first put on the support bracket which has holes for the breather bolts to go through and holes that line up with the holes on the carburator.
Problem I am running into is getting the bracket flush on the carb base. I got a new gasket in there but the hose that brings the fuel into the carb runs along the side of the left breather hole and prevents the bracket from mounting flush.
Any suggestions? I figgered if I posted here either Dan would see it and respond or someone else who has installed the Hurricane would respond.
Erica in KC (Red)
"Ruth" '05 XL883C -> 1212 -> 1235 (don't ask) - Pearl Yellow
Progressive Fork Springs, Progressive 412s w/ heavy duty springs, 883 -> 1200 NRHS conversion (at 1235 Now), Daytona Twin Tec Ignition, Hurricane AC
Old 9th November 2008
bump
TnG TnG is offline
TnG has a spectacular aura aboutTnG has a spectacular aura aboutTnG has a spectacular aura aboutTnG has a spectacular aura aboutTnG has a spectacular aura aboutTnG has a spectacular aura aboutTnG has a spectacular aura aboutTnG has a spectacular aura aboutTnG has a spectacular aura about
I switched to a mikuni when I did mine, but as I recall the fuel inlet was moveable with a little persuasion, and I was able to sneak the fuel line in. Perhaps the stock carb inlet has some room to move also?
2006 XL1200C Paint by me, NRHS 1250, Stage II Heads, .575 Cams, TC88A, Mikuni 42mm, D&D 2 into 1, Hurricane 3" A/C, Golan manual petcock. Best 1/4 ET: 11.79et @ 112.51mph :-)
floorit's Avatar
floorit floorit is offline
Sportster/Buell Model: 1200c
Other Motorcycle Model: Honda XR250r
Other Motorcycle Year: 90
floorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to beholdfloorit is a splendid one to behold
I went out and looked at mine. The fuel hose should be slid back between the part of the head that is rounded, where the breather bolt threads in. And the top of the carb. My bracket doesn't even touch the hose. Is it a Drag Specialties bracket? Thats what they sent me. If you REALLY need me to I can take a pic and sent it to you.
misterT's Avatar
misterT misterT is offline
Sportster/Buell Year #2: 1976
I have a Mikuni on mine now but when I first put the Hurricane air cleaner on I had a CV 40 carb. I remember that I rerouted the fuel line and I also used an extra washer on each side between the carb bracket and the cylinder heads. I did not have the horse shoe breather though I have the drag specialties one with hoses and a filter. I believe that I saw some pictures of Turbotas set up with a horsehoe breather though.
FoxsterUK's Avatar
I'm assuming its the Buell bracket they supplied? If so then I used the same one and I got it from NRHS. It is a little tight on the fuel hose. I put extra washers between the bracket and the heads and then it only pressed lightly on the hose, in fact its not the actual hose its the cover for it and the hose inside is under no pressure.
Fox
rfranz1952's Avatar
rfranz1952 rfranz1952 is offline
Sportster/Buell Model #2: XLX
Sportster/Buell Year #2: 1985
Other Motorcycle Model: Yamaha Vino 125
rfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nice
Its a tight fit. I have a picture in my gallery of how it came together on mine. You can see part of the carb top, the carb bracket with the fuel hose in behind it, and one end of the horseshoe. It looks a little pinched, but I think that is just the corregated covering to the fuel line, and the line itself is not pinched.
I hope this is helpful.
http://xlforum.net/photopost/data/50...ch1_Small_.JPG
2005 XL 1200 Custom; NRHS 1250 Conversion, 10.5 - 1; Stage 2 Heads; SE 536 Cams; Jim's Hydrosolid lifters; NRHS adjustable pushrods; S&S Roller Rockers; Crankshaft by Darkhorse Crankworks; HurricaneFlow A/F; Hurricane Oil Filter; Mikuni HSR-42; S&S Intelligent Spark Technology Ignition; RB Racing LSR exhaust; Front and Rear Progressive Suspension; Oversize front tire; Superbrace Fork Brace; Speedway Microtach, lots of other bits and pieces.
THE $16,000 Sportster!
Old 10th November 2008
Do you have the chrome or black bracket? The horseshoe does not work with the chrome bracket only the black ones.
Old 11th November 2008
I have the black bracket.
That picture is exactly what my set up looks like Rod. I'm waiting for a warmer day to get back into the garage to play around with it.
