0 Brake cable on 72 xlch forward controls
0 Shotgun Porn
0 my '82 XLS Roadster project
Last Post: N-Rico
0 Let's See Them R's!!
Last Post: grako122
Last Post: Skuzeee
Last Post: vagrant318
0 The forum got talent
Last Post: Skuzeee
0 900 heads contd..
0 Oil and smoke everywhere
Last Post: fbroos73
0 65B genr8r I hecked up
Last Post: Kaptain
0 attn DR DICK
0 Fixing a loose mirror
Last Post: Yochstein
0 Timing after dynatek 2000i install
Last Post: jordan1200
Last Post: felis
0 Timing issue
0 Can’t get upper triple tree removed. Advice?
Last Post: speedfoos
0 Oil pump working, no oil to rockers
Last Post: shovithead
0 project 74 sporty
Last Post: the cowboy way
0 Aligning ‘14-newer OEM exhaust?
0 Front brake combination not working well. Suggestions?
0 JACKHAMMER 570 Cams!
Last Post: md1200
0 Do you run MAXIMUM PSI?!?
Last Post: Edster
0 loose needle bearing in cam chest
0 My oil changes just got easier
Last Post: Tucsonmax1
0 ‘68 XLCH...transmission
Last Post: chevelle
sflier, dubi1946, unclesumo (61), 81ironsporty (59), cheyenne71597 (58), akk (58), MDRide, JohnK (54), 86stang (53), Dusty1985 (33), evokid8 (27)
Old 27th March 2007
FSZEKE302's Avatar
FSZEKE302 FSZEKE302 is offline
US NAVY Vet, ADR2
Other Motorcycle Model: FXD SuperGlide
FSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the roughFSZEKE302 is a jewel in the rough
Battery cables carry a high Amp load when starting. If the cables are not Tight enough, Or Clean enough you will have a high resistance connection. Under high amp draws there will be a significant heat build up at the connection. Thru expansion and contraction of the posts and connectors the connection will become even looser. Sometimes to the point you'd think someone loosened them. If you lubricate the connections with a good electrical grease, [Vasoline works well in a pinch] and tighten them properly, chances are good you will have a good connection for years. This was probably the No1 most frequent problem we had when I was in a Marine engine repair shop. Biggest cause, which doesn't apply much to Motorcycles, Marine batteries come with wing nuts, Wing nuts are the Worst way to connect a battery cable. We use SS Star lock washers and SS
Nuts, lubricated and tightened properly with a wrench. Very few problems.
ZEKE] Old and Proud 1994 XLH [Black of Course] " A fear of weapons is a sign of retarded sexual and emotional maturity " -Sigmund Freud http://xlforum.net/photopost/showgal...r=3484&cat=500
US NAVY Vet, ADR2
Old 27th March 2007
chorister's Avatar
chorister chorister is offline
Sportster/Buell Model: XL 1200 Low
chorister has disabled reputation
I quite often got to my bike in the morning and get nothing or
'click-click-click'. It's ALWAYS a loose terminal or battery strap. How the hell she loosens it off by herself overnight I'll never know!
Mice....perhaps?
Old 1st April 2007
Jings Jings is offline
Sportster/Buell Year: 07
Jings is an unknown quantity at this point
Hi guys - just new to the forum and have to say its great but I was hoping to pick someone's brain about a problem with my wife's 07 1200r. She dropped it last Saturday but we got it up and no problems were found - hardly even a scratch. She rode it about 70 miles back home and the next day i washed it and took it for a spin with no trouble. 6 days later i went out to start it and the battery was completely dead. I put a voltmeter on it and it showed 0.03volts - any ideas?
Old 15th May 2007
br_xl's Avatar
br_xl br_xl is offline
br_xl has disabled reputation
Have you read the entire thread? Once you check everything as suggested, post back.
Old 15th May 2007
br_xl's Avatar
Two starting and/or running problems.
Bad key switch: accelerated wear by allowing keys to blow in wind.
Fuel petcock: vacuum leak, no fuel flow.
Old 15th May 2007
unfiguroutable's Avatar
unfiguroutable unfiguroutable is offline
Sportster/Buell Model: XL883L
unfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the rough
Originally Posted by Kev M View Post
Remember a circuit ONLY works when it is complete (when it makes a circle, from the positive side of the power source, through a load and back to the negative side of the power source).
this statement is slightly misleading. common ground is required not a perfect loop.
Old 21st May 2007
XLFREAK XLFREAK is offline
I'm having the same issue with my '07 1200 Custom with 535 miles on it. I've had the "turn it on, press start, hear a click, all lights go out" issue 3 times so far. I actually caught it on video one time.
I'm going out right now and doing the suggested tightening of everything.
This is the type of thing I wanted to avoid by paying $10K for a NEW bike!
Old 21st May 2007
update: I pull out the battery and the positive side I could wiggle the wires back and forth. On the negative side the bolt I could twist with my fingers!
So, I tightened and went for a ride and it seems to run smoother with less "huccups"....
Ah go figure.......the simplest things....
Old 26th May 2007
belrix_76's Avatar
belrix_76 belrix_76 is offline
belrix_76 is an unknown quantity at this point
Had a similar problem the other day. Went to start my sport and the lights didn't some on. Figured I didn't turn my key all the way off. Comes out in the ACC position. I hooked my charged up for a while and got the click-click-click. An of course being the patient Gen-X'er I turned my charger to 50 amp jump mode hit the started and poof nothing no light. So this weekend I get to check fuses and some wiring to see what I fried. Being the brilliant aircraft electrician I should have known better. 02 sportster is a little more touchy than a 60' CH-46.
Old 6th June 2007
joec78xlh's Avatar
joec78xlh joec78xlh is offline
Sportster/Buell Model: xlh1000
joec78xlh is an unknown quantity at this point
Heres one for you guys to ponder I got a 78 xlh i was having a charging problem so i replaced the generator cause the brushes and stuff were shot. When i replaced that i also put in a new battery and regulator. I got it started and running then i went to start it up a day later all i got was the usual click i at the relay i checked all connections everything was fine. I then checked the voltage coming out of the solenoid and i was getting 1.94 volts so i figured that must have went also. So i replaced the starter solenoind and relay. And boom it fired right. Well I needed to adjust the carb so i was working on that so i get it pretty well set up then i shut the bike off and thought i am good to go. I go back out and try to start it it turned off a couple times then i got the click again. I checked everything like the first time and low and behold the solenoid was doing the same thing. I checked for continuity and here i am getting a ground from the starter. I pulled the starter out of the bike and pulled it apart and found a good bit of wires inside were pretty bare. WOuld anyone know if this could be causing me to blow the starter solenoid. ALso does anyone know if the starter solenoid might still be good if is showing some voltage through it. I am going to the indy today to get a new starter but i was hoping i might not be able to save the fifty it will cost for a new solenoid. thanks for the help guys
