0 Fuel pump replacement
Last Post: nativebroncofan
Last Post: Lone Rider
0 Turn signals and switch required 1972 xlch
0 Crank Assembly problem or Cams Knocking????
Last Post: acable23
0 Morris mag wheel question
Last Post: USAFpj
0 Longtime XL owner, 1st time forum joiner
0 Hey, new guy from Detroit
0 28 years later..
Last Post: USAFpj
0 How to eliminate TSM on 2000
Last Post: steveolds
0 Clutch issues
Last Post: bassgrinder
0 cscycle service Mt. Victory , Ohio
Last Post: Larry May
0 oil filter choices
0 Primary will not seal
Last Post: dodgetrucken
0 Upcoming 1275 hammer upgrade carb choices
0 Oil cap problems - Bikers Choice 02-073
Last Post: dieselvette
0 Hello with new to me 60’ xlch
0 EFI hose clamps
0 New member 76 sportster
Last Post: jaa55
7 Hy from Austria
Last Post: heyshott 81
0 Leaking Head Gasket, Loose head bolts
0 Sportster. Xlh model. 1982
0 Front end swap
Last Post: stalkie
Last Post: lehel
0 1975 XLCH1000 Splitting Cases
Old 13th June 2019
LenC's Avatar
LenC LenC is offline
Sportster/Buell Model: NRHS 1250
Other Motorcycle Model: Triumph Bonneville Black
Other Motorcycle Year: '06
LenC has disabled reputation
Originally Posted by decman View Post
The memory is the second thing to go...
Ain't that the truth.
If it wasn't for the splatter I wouldn't carry the damn thing around anymore for all the good it's doing me.
Hey, speaking of, I see you're not too far away from Riverton.
I'd have you look up an old girl friend of mine but I'm guessing her husband would be less than understanding.
Old 14th June 2019
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Don't know that many folks from Riverton.
I do have a couple of MC customers that bring their bikes to me
here in Dubois.
Old 16th June 2019
canoli's Avatar
canoli canoli is offline
Default Nut Sizes??
Glad you got it sorted!
eventually I'll need to check out my tranny... what size are the nuts on a 1992 belt drive? They say a picture is worth...do I have it correct? If so, where is this 1-7/8" nut referenced in Sportsterpedia (about halfway down the page)? It says "Final drive (Trans to wheel)" ... ?
sportsterpedia.com/doku.php/techtalk:evo:transfinal03
Thanks you guys!
Old 16th June 2019
That final drive, trans to wheel, is the opposite side on the output shaft.
Old 16th June 2019
canoli's Avatar
Oh right....thanks Paul - had an extended brain cramp going there for awhile.
Thanks again!
