0 Turn signals and switch required 1972 xlch
Last Post: Lone Rider
0 Crank Assembly problem or Cams Knocking????
Last Post: acable23
0 Morris mag wheel question
Last Post: USAFpj
0 Fuel pump replacement
Last Post: nativebroncofan
0 Longtime XL owner, 1st time forum joiner
0 Hey, new guy from Detroit
0 28 years later..
Last Post: USAFpj
0 How to eliminate TSM on 2000
Last Post: steveolds
0 Clutch issues
Last Post: bassgrinder
0 cscycle service Mt. Victory , Ohio
Last Post: Larry May
0 oil filter choices
0 Primary will not seal
Last Post: dodgetrucken
0 Upcoming 1275 hammer upgrade carb choices
0 Oil cap problems - Bikers Choice 02-073
Last Post: dieselvette
0 Hello with new to me 60’ xlch
0 EFI hose clamps
0 New member 76 sportster
Last Post: jaa55
7 Hy from Austria
Last Post: heyshott 81
0 Leaking Head Gasket, Loose head bolts
0 Sportster. Xlh model. 1982
0 Front end swap
Last Post: stalkie
Last Post: lehel
0 1975 XLCH1000 Splitting Cases
Last Post: Joe_jeep
brake cable
don_don465 don_don465 is offline
Sportster/Buell Model: XLH 883 Deluxe
Other Motorcycle Model: 2016 Yamaha FZ09
don_don465 is an unknown quantity at this point
Default true length of after market brake cable
new to the forum,
i was wondering if anyone on here with an after market stainless/vinyl front brake cable could tell me the true length of it.
Also whether it is +2"/+4"/+10" or what ever the custom order you made might be so that i can determine the length of a stock one to be made.
I would like to have one made by Coremoto and would rather find a true length of someone who has on than try to make an estimated number to avoid any extra slack or being to short. it seems as though all of the ones i have looked at online to not show a length in the Specs, just the diameter of the line.
I apologize if this is being asked in the wrong section and appreciate any help/guidance i can get.
thanks
Don
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Not sure why you insist on going with "Coremoto" but, the major companies such as Magnum Shielding and Barnett know exactly what size you need if you tell them the model of the bike you've got. They will also cut you one that is a custom length, if you wish, for not much more than the stock length.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
