0 Mid West Meet & Greet
0 Gel in seat for rigid?
Last Post: trappnman
Last Post: a-sad-anorak
0 Base line jetting for S&S Super with Thunderjet
Last Post: ftwflh
0 Cam position sensor
Last Post: ftwflh
Last Post: 72 Ironhead XLH
0 900cc Pistons
Last Post: mickey t
Last Post: tattooglisha
0 Le Pera seats in Australia
Last Post: BSA Bob
Last Post: RDHenley
5 Terminology Sticky?
Last Post: commando57
Last Post: RDHenley
0 No oil flow
Last Post: MkC
2 Your daily tunes...
Last Post: RDHenley
Last Post: batchman
Last Post: SwissXL
0 Highway cruise speed
Last Post: SwissXL
Last Post: Kenb
0 Getting Hammered
Last Post: Bryan83taco
0 Willi is back!!!!
Old 8th April 2020
Parker 1000 Parker 1000 is offline
Sportster/Buell Model: Xlh/Xlch
Sportster/Buell Year: 1976
Parker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to behold
Default 1970-71 XL Fuel Tank ?
Is the 1971 Sportster small fuel tank exactly identical to the 1970 with the small overflow tube right up inside the filler neck?
Old 8th April 2020
The Doctor71 The Doctor71 is online now
Sportster/Buell Year: 1971
Sportster/Buell Model #2: xlh
Other Motorcycle Year: 2011
The small fuel tank p/n 61000-54C appears to be used in both 1970 & 1971 (and earlier) so the simple answer is "yes".
Regarding, the small overflow tube inside the filler neck..... yeah it looks like it might be an overflow tube. I get it. But it's really a vent tube for the Tillotson carburetor.
The hose running from the top of the Tillotson, to the nipple on the bottom right corner of the tank is how H-D chose to vent the Tillotson carb. At least that's how it's done on my '71 xlch.
Old 8th April 2020
Thanks Doctor '71! So the original 1971 tank has the vent tube for the Tillotson Carburetor also?
Old 8th April 2020
Correct.
Old 8th April 2020
Tim The Grim's Avatar
Sportster/Buell Model #2: KHK
Sportster/Buell Year #2: 1954
Other Motorcycle Year: 96
Just to confirm...
I bought this tank new, from an H-D dealer, in January 1971.
It has the tube.
It also has a lot of sentimental value so it sits on a shelf as is.
Old 8th April 2020
Thanks guys!
Old 8th April 2020
1971 would have been the last year for the Tillotsen and the need for the tank vent.
Old 9th April 2020
Whitewalls's Avatar
Other Motorcycle Model: 1966 Honda Dream 160
Whitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant futureWhitewalls has a brilliant future
Very interesting. I have an early '71 XLCH and the tank does not have a tube. When I stripped the tank prior to sealing and painting I noticed a date stamped on the bottom 12/70. It was a basket case sans a carburetor so perhaps the tube was removed by a previous owner.
Old 9th April 2020
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
Almost right , my 1972 came with that tank but the bottom of the tank had a cap over it Bendix did not use any venting from the tank, Tillotson did
